Tom's Hardware > Forum > Motherboards & Memory > Abit > IP35 Pro RAM Problems.
Hey there,
Built my first ever computer the other day,
Specs:
IP35 Pro motherboard
2x 1gb Crucial Tracer Ballistix Ram
Corsair T650W power source
Asus EN8800gt graphics card
Everything is now running perfectly except for one thing:
Only one stick of ram can be detected at a time!
There are four DIMM slots, and currently have the modules in DIMM1 and DIMM3 however only the one in DIMM1 works. I have tried both modules in DIMM1 to ensure that they are working and they are both fine. If i use the DIMM2 and DIMM4 configuration, neither of them work!
I have set memory speed to 5-5-5-15 and changed voltage to 2.2v and still only DIMM1 works. Also upgraded bios and still no luck. I'm a complete newbie at this so bear with me =D.
Do I have a faulty motherboard or is there something that i'm missing?
Sponsored Links
TRY TO CHANGE THOSE RAM ! FAULTY INCOMPATIBLE RAM, TRY USING CORSAIR XMS DMS 6400 4GB LIKE MINE.
Reply to Anonymous
I would install them in dimm1 and 2 leave 3 and 4 empty. let me know
Reply to bmdowney901
Try to increase the MCH Voltage to 1.29V with one stick installed then install all of them
Had this issue with Four crucial Ballistix 800mhz 4-4-4-12@2.2V
Good luck
Reply to RavenXE
There are 1281 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
