Tom's Hardware > Forum > Overclocking > General Discussions > Help Overclocking E8400+Ep45-UD3P
Forum Overclocking : General Discussions - Help Overclocking E8400+Ep45-UD3P
I am doing my first overclock with following system build:
E8400@3.0Ghz EO
Ep45-UD3P Rev. 1.1 F9
2x2GB G.Skill PC2-8500CL5D (defaulted @800Mhz so manual set to 1066Mhz)
Arctic Cooling Freezer 7 Pro
512MB Sapphire HD 4870
Antec 1200 Case
Antec SG850 PSU
Windows 7 RC
I have made several attempts to Overclock following several guides and settings that have worked for others with similar systems. My goal is to end up with around 3.6Ghz on this initial go-around. Each attempt passes POST and then boots the OS. The desktop pops up and either during or after the startup chime the system will freeze resulting in a constant sound if stopped mid-chime. While at the stock speed of 3.0Ghz I have performed various tests including Prime95 resulting in load core temps of around 50C and idle temps at 31C. If I need to post additional info please let me know.
Sponsored Links
Hi katoomba, welcome!
I guess the best way people here can help you is if you list the current settings you're using, particularly voltages?
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
1) Read the sticky
2) Post all your settings
3) An overclock of that speed is likely, but not guaranteed so don't automatically expect it.
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
There are 1077 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
