Latest Reviews & Articles
Perfect Notebook Storage: Seven 2.5” 500 GB Drives
We compare the latest 500 GB notebook drives from Fujitsu, Hitachi, Samsung, Seagate, Toshiba and WD. Seagate is first manufacturer to reach 500 GB at 7,200 RPM, but which is really the best drive? We loaded up our updated test system to find out. Read more
Mainstream Graphics Card Roundup
You don’t always need the fastest graphics card around. For somewhere between $135 and $235, you can game like crazy in DirectX 10 without a problem at 1920x1200. We test and compare five graphics cards from this mid-range price segment. Read more
USB 3.0 Ups Peripheral Bandwidth
The new USB 3.0 interface is just about ready. It'll accelerate throughput from the 480 Mbit/s of today's USB 2.0 to 5 Gbit/s, which is important for storage and peripheral devices. But USB 3.0 also introduces power saving options. Read on for more. Read more
Your 64-Bit Check List: Potential Issues You Might See
Hardware and software support for 64-bit operating systems is available, but the full 64-bit reality may still cause you some distress. We created a short summary of things you need to take into account before installing a 64-bit OS for the first time. Read more
All the Reviews & Articles
Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > Gigabyte ga-7n400S sound problem
Please help, I can't connect subwoofer/center speaker.
When I connect those speakers, jack sense application doesn't sense them and I don't have sound on those speakers.
Other speakers work fine.
Sponsored Links
the software of most sound devices has an option to disable the auto detect feature. If you don't find it, maybe you could tell us which sound card you're using.
Reply to rojito
It has that option, but even if I manualy select proper speakers still I have no sound. I'm confused because other speakers (rear and front) work just fine.
Sound card is onboard audio device realtek ac 97 and it has three jacks, green, blue and red (out, in and microphone), but when I turn on 6 channel mode, microphone and line in jack are used as subwoofer/center speaker and rear speaker output.
Reply to i_separovic
- 0 +
1) Update you audio driver and tell me what happens.
2) If you happen to have a Logitech webcam, uninstall its software and driver and if the problem is solved install only the driver.
Message edited by rojito on 09-15-2008 at 11:11:35 PM
Reply to rojito
Than You
I tried all that (don't have Logitech, but Genius webcam and I uninstalled it)
but still no sound from sub/center speaker. New driver doesnt help.
Is there any way to bypass sound config and to force onboard card to send sound trough center/sub channel? Probably connector sensing doesn't work.
- 0 +
Well man, I'm out of options. You should try calling gigabyte, if no luck return it or buy a cheap audigy.
Ahhh, and make sure its not your cable or speakers. plug some headphones and listen for center channel audio (one side)
Message edited by rojito on 09-17-2008 at 04:04:15 AM
Reply to rojito
There are 1106 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
