Ok I've been doing alot of reading and now I'm confused,lol
I want to buy a UPS of 700W which has a VA rating of 1000.
This is what is indicated in the manual:
3.3 Determining How Much Equipment You Can Connect to Your UPS
1. Make a list of all equipment that requires protection.
2. Each piece of equipment has voltage and current (VA) ratings printed on
the back label (see examples below). Your equipment may have a voltage
rating such as 88-264V. Since the standard voltage in the United States is
120V, you should use 120V in your calculations.
ViewSonic G810
120V 2.7A
50 / 60 Hz
Computer
Pentium Pro 200MHz
120V 2.0A
50/60 Hz
3. Multiply the voltage and current of each piece of equipment (VA
requirements); for example, 120V x 2.7A = 324VA, 120V x 2.0A = 240VA.
Add up the VA requirements for each device; for example, 324VA +240VA = 564VA.
4. Make sure that your UPS has at least as much VA capacity as your
equipment requires.
Now I'am confused concerning my PC's PS.
It's a 600W OCZ gamextreme
Its says its input Current is 6A @115V
So if I calculate this for lets say 120v @ 6A=720VA !!
Now this is just for calculation figures as I know my PS doesn't pull 100% at all times.
So I'm seeing that this UPS with 1000VA is NOT enough for my PC and monitor.Which I think is impossible and I'm not calculating something right.
Please can someone explain?
ViewSonic G810
120V 2.7A
50 / 60 Hz
Computer
Pentium Pro 200MHz
120V 2.0A
50/60 Hz
equipment requires.
