please would you mind taking a look at what i intend to purchase and give any feedback. would be most appreciated. just one thing, i have decided to go amd. i like to play games.
Honestly, that memory is a ripoff. You can get 4gb of DDR2 800 with the same timings for the exact same price.
http://www.newegg.com/Product/Prod [...] 6820145194 Get those if you really want to stick with corsair.
But theres still a lot of RAM which is cheaper and is still DDR2 800 CAS 4.
EDIT: If you wanted that memory because its "SLI ready" its still not worth it in the least bit.
hi doomturkey
im in the uk- the ram you mentioned is 2x the price of the one i chose!
Hmmm....recommendation?
Just buy the best deal you can find. Any from Corsair, Crucial, Kingston, Patriot, and Mushkin will do just fine.
I use 2x2GB from Mushkin.The reason, why I have bought it, was simple. If you find a 2x2GB kit that costs only $15 more than a 2x1GB kit (the same brand), which one will you buy?
It was on a special sale.
------------------------------Intel Q6600 @ 3.0GHz + ASUS P5E X38 +
4GB DDR2 1000 CL5 Mushkin + Coolermaster Dominator Xcalade 690 + Corsair VX 450W + HIS HD 3850 512MB Turbo + Seagate 500GB 7200rpm 32MB + Zalman CNPS 9700 LED + Logitec EX110 + ASUS VW198S.
Reply to guanyu210379
