I added another gig of memory, for 2 sticks of ram total. I also added a 2600xt 256mb pcie card. So far it runs just fun when I game (COD4). However I am thinking of adding another harddrive (IDE 7200rpm 500gb WD) and I don't know if the 300watt PS will handle the extra drive. What do you guys think? I would rather not buy the extra PS if I don't need it because I'm tight on money. However if I do need it, can you guys recommend a cheap power supply (the cheaper the better). I don't really plan to do anything else to the computer, I just need the extra HD to work.
DDR...IDE...AGP? Any upgrade would be money wasted. Instead, why don't you get a newer system that supports DDR2, SATA, and PCI-E?
If you are intent on upgrading, you will most definitely need a better PSU. I own a similar emachine and it's 300W PSU is crap. Couldn't support a 6800 at all.
yeah well my 2600xt plays COD4 at decent framerates (~35 at all high settings) and that is more than enough for me. I just want a new harddrive to store media, and I'm pretty sure there is a converter to change IDE to SATA if I were ever to upgrade to a SATA system. Getting a whole new machine is not an option for me, and as I had not asked about that, I don't understand why it would be brought up. Not everyone is rolling in money.
So my question remains, will my 300watt PS hold up the new harddrive?
i would be concerned about adding another harddrive. typically those machines are made with the bare minimum to support the components and low quality psu at that.
