Tom's Hardware > Forum > CPU & Components > Sound Cards > Front Panel Audio with Creative X-FI PCI-e
Forum CPU & Components : Sound Cards - Front Panel Audio with Creative X-FI PCI-e
Just installed my new Creative X-Fi PCI express sound card because the onboard audio from my eVGA 790i was not great. The audio on the back panel works fine but the front panel audio stopped working. The card description supports intel HD audio but not AC97. I plugged in the HD audio connector into the card but for whatever reason it doesn't work. There's more info on the card here (http://support.creative.com/kb/Sho [...] x?sid=1273). Can anyone explain why this isn't working?
Thanks
Sponsored Links
hd audio and ac97 use the same jack but the pin outs are different. with a little bit of modding, you can get it to work, but you have to know the pinouts of each and move pins around in the jack. worked for me. intel has the pinouts of both of them, so search around. its quite easy to do
------------------------------ Q6600 @ 3.6GHz|2GB Crucial Ballistix Tracer|DFI P965-S Dark|8800GT 512MB|Raptor Main Drive|Audigy X-Fi (Modded)|Rocketfish Case with H2O|
AMD Athlon X2 4800+ @ 2.7GHz|OCZ Golden Gamer @ 450MHz 2.5-3-2-5, 1T|250GB Main Drive|2900XT|NZXT Zero w/ h2o
Reply to lambofgode3x
I have the same card. The card will only output sound when directly connected to one of the cards own output jacks. As such, the card will not use the front panel (you can switch back to the onboard drivers though, which is what i did).
Also make sure that the default sound output device is set to the Creative card.
Also, nForce motherboards do not like creative cards. In my case, I get distorted sound after about 30 minute to an hour of running the same app. I would recommend getting a card from a diffrent brand if you stick with the 790 mobo.
Reply to gamerk316
Hi,
in the audio console from your x-fi (please install a recent driver, not a beta one), uncheck "automaticly detect headphone".
When you use ac97 for the front audio, it thinks headphone are not plugued.
Brad
Reply to djbrad007
you can actually make an adaptor that plugs into the creative card and works with the front audio panel. there are ways to do it without modding the card, but i decided to desolder the white jack and soldered in 3pin fan headers. i'll take pics of the card when i get home and post them if anyone's interested. it was simple but its a good way to kill the card if you dont know what you're doing
@djbrad007
I installed the drivers with a supplied creative CD then ran autoupdate so drivers should be recent. However in either the "Creative Audio Console" or "Creative Console Launcher" I find no option to "automatically detect headphones". Can you be more specific?
Reply to lex-luther
@lambofgode3x
My motherboard has two audio pin headers - one for "HD Audio" and another for AC97. I don't understand why I would need to modify the pin layout if I use the HD Audio connector.
Reply to lex-luther
i mean to connect your front audio connector right to the sound card that way you can use your front audio connector and the xfi so you dont have 2 sound cards eating up resources. i'm just letting you know how i did it.
edit: which sound card exactly do you have? that would really be helpful cuz the best thing to do is to get your front panel audio to go right thru the card itself and disable the onboard sound
Message edited by lambofgode3x on 08-21-2008 at 09:28:26 PM
@lambofgode3x
I'm not following you... Why do you think I would use two sound cards if I disabled the onboard audio - I'm only using the Creative X-Fi at the moment. What is confusing me is the difference between "Intel HD Audio" and Intel compatible HD Audio.
I found this on Creative's Site: Click "start here" then "No sound from headphones or microphone connected to a PC's front panel".
Sound Blaster X-Fi Xtreme Audio and Sound Blaster X-Fi XtremeGamer feature the Intel High Definition Audio (Intel HD Audio) Front Panel header.
This header follows the standard 2x5pin Intel HD Audio conform layout. It is not compatible with AC97 or Intel-compatible HD Front Panel Audio, as their pins are assigned differently.
What is the difference between "Intel HD Audio Front Panel header" and "Intel-compatible HD Front Panel Audio"?
*edit: link was not working*
Message edited by lex-luther on 08-21-2008 at 09:39:19 PM
Reply to lex-luther
basically what i was trying to say is to use the cable that plugs into your motherboard from your case and modify it so that it works with the sound card.
i say plug in the jack labeled hd audio and see what happens.
I plugged in the jack that says HD Audio. The system does not detect headphones are plugged in. However, if I right click on my Vista sound icon in the system tray and select "Playback Devices" I can manually set headphones as default. It's pathetic that my onboard audio worked better than this Creative add-in card. Hopefully there is a way to fix this autodetection issue.
Reply to lex-luther
this is why i swore off creative sound cards after my initial hastle with my x-fi. i got my hands on the ht omega striker and claro sound cards for 2 gaming builds that i put together for customers and it has ac97 pinouts. that and the 80 dollar striker sounds better than my x-fi platinum, so i was kind of mad about that.
edit: come to think of it, my xfi didnt turn off my speakers even when i used the front bay that came with the sound card.
Message edited by lambofgode3x on 08-21-2008 at 10:38:07 PM
if you have speakers that are just a single 3.5mm jack, then i suggest this:
http://www.newegg.com/Product/Prod [...] 6826265015
switch between speakers or headphones via a rocker switch. they work pretty well and don't degrade the signal like regular splitters usually do
There are 458 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
