Tom's Hardware > Forum > Overclocking > AMD > Problem overclocking amd 720
Forum Overclocking : AMD - Problem overclocking amd 720
Im new to overclocking and am having problems. I went into the bios changed the cpu frequency to several different options such as x12.5 2500 mhz and when i save it and the pc goes to restart it does not restart and I have to reset the motherboard. I also tried to change the cpu voltage from 1.25 to 1.45 and still no luck. Can anyone offer me any help here, I would really appreciate it as I just built my first machine and am learning. Thanks!
Sponsored Links
you have a Black Edition, just change the multiplier up (no need to change the base clock)
go from 2.8GHz (14x200) to say 3.2GHz(16x200)
Reply to mindless728
- 0 +
I appreciate the advise but when I change only the multiplier and save it, my systems goes to reboot and does not. The power button turns off but the fans, motherboard and video card continue to run. I have to to the reset button the motherboard to get it to reset and then it reboots back to the bios so the date and time can be reset. Ive search online for an answer and still can not figure it out. I also have two DDR3 1333 2gb memory sticks and it shows they are only running at 533mhz and I cant seem to get those to clock at the listed rate. Im about to kick this thing!
Reply to johnb23
- 0 +
What is the mother board you are using. Changing the memory from 1066 to 1333 is as easy as change the cpu multi from 14x to 16x. Will help greatly if we get the mobo so we know what we are dealing with
------------------------------ AMD 955BE @ 3200, 1.18V><Gigabyte GA-MA790XT-UD4P F5 BIOS><8Gb OCZ 1333 PLAT @ 1333 6-6-6-18 1T 1.95V><ATI 4870 1Gig (840core 1000mem)><Lian Li PC-A71><Corsair HX-750><BenQ V2400W><Microsoft Wireless Entertainment Desktop 8000>
Reply to bmadd
- 0 +
I have a ESC A790GXM-AD3 which is suppose to make overclocking easy. Let me know if you need anymore information so you can lend your help. The wierd thing about the memory is that the bios show it reading as 533Mhz, and the memory is rated for 1333Mhz. I have been busy the last 4 or 5 days so I havent had a lot of time to play with it. Let me know what you think and thanks again for any help.
Reply to johnb23
Your ram is running 1066. Just change the settings in your bios. Take some pics of your bios and we can help :D
My asus mobo had my ram running at 1066 as well...when it's rated 1600 lol
Reply to AlphaOmegAX
- 0 +
I have a 720 BE and just change the multiplier until the system freezes then back it off a half and check stability with prime 95. If it runs for atleast a couple of hours, I save the profile. I up the multiplier back to where it froze last and up the voltage just enough to not freeze. I got up to 17 times on the multiplier at 1.425 volts with the max CPU temp not going above 51c. I didn't want to go above 1.45 v with the stock HSF so I stopped there. I read the safe voltage max with a good cooler is somewhere between 1.45 and 1.55. I think it will likely top out with a good cooler at either 18x or 19x but cant say for sure until I get a better CPU cooler.
Reply to NeilCar
There are 444 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
