Help on $1200 build
Forum Homebuilt Systems : New System Build - Help on $1200 build
I can spend up to $1200 on a gaming pc but it must include a monitor, speakers, etc. I do have an OS but that's it. Can somebody help me pick out parts for it? I want it to be a Crossfire configuration.
Sponsored Links
I am not sure if you need them but I included the mouse and keyboard as well. Total price = $1,229.00
Case
http://www.newegg.com/Product/Prod [...] 6811119094
mobo
http://www.newegg.com/Product/Prod [...] 813131219R
GPU
http://www.newegg.com/Product/Prod [...] 6814102747
PSU
http://www.newegg.com/Product/Prod [...] 6817341002
CPU
http://www.newegg.com/Product/Prod [...] 819115037R
RAM
http://www.newegg.com/Product/Prod [...] 6820227267
HDD
http://www.newegg.com/Product/Prod [...] 6822148288
Mouse
http://www.newegg.com/Product/Prod [...] 6826246011
Keyboard
http://www.newegg.com/Product/Prod [...] 6823175104
Monitor
http://www.newegg.com/Product/Prod [...] 6824009108
CPU Fan
http://www.newegg.com/Product/Prod [...] 6835186134
CD/DVD Burner
http://www.newegg.com/Product/Prod [...] 6827129018
The final price does not include any mail in rebates or combo deals. The only "specials" I used were a couple of open box parts. I didn't add speakers because you can go to Wal-Mart and get a decent set of speakers or headphones for $25-$30. The onboard audio is very good so a sound card is not necessary. Last thing, I did not use 2 x GPU's because of your price point but a 2nd can be added later if/when necessary.
Hope this helps.
Message quoted 2 times
Message edited by mexpedip on 07-02-2008 at 04:58:42 PM
Reply to mexpedip
- 0 +
cooler master cm 690 ~85$
4 gb ddr2 800mhz (corsair xms2 dhx ) ~80$ after mail rebate
e8400 processor ~190$ (can get the e7200 for 130$)
corsair 750tx power supply ~110$ after mail rebate
gigabyte x48-ds4 mobo ~225$ (maybe change it for a cheaper x38 one)
seagate barracuda 500gb ~80$
radeon 4850 ~170 with mail rebates
xigmatek cooler with brackets ~40$
Total: ~980$
Add to that a monitor and speakers of your choice for ~220$
This build rocks, you can definately go crossfire later and get both cards at 16x. You can also overclock very well. Even a corsair 650tx power supply would fit. Search a bit around this build and try to get better prices.
________________________________________________________
Another one with crossfire but each card limited at 8x
e7200 processos ~130$
asus p5q pro motherboard ~150
2 radeon 4850 ~340 with mail rebates
Total: ~1015$
It would let you 185$ for monitor and speakers... if you want crossfire now work on this build and try to get cheaper components but the first build would be better for sure.
Message quoted 1 times
Message edited by georgy on 07-02-2008 at 04:55:12 PM
Reply to georgy
Thanks guys I'll have to consider them.
Reply to matt2012
Case
mobo
GPU
PSU
CPU
RAM
HDD
Mouse
Keyboard
Monitor
CPU Fan
CD/DVD Burner
Hope this helps.
Yeah I forgot to mention that I didn't plan to do CF yet, I just wanted to be able to do it eventually. Thanks.
Reply to matt2012
- 0 +
Case
CD/DVD Burner
Hope this helps.
I'm too lazy to follow your links. Too bad you didn't actually say the part names and prices. I gave up at the IDE burner and open box MB, by the way, I wouldn't buy those.
Message edited by aevm on 07-02-2008 at 05:24:27 PM
Reply to aevm
I actually just recently built a pc a couple of months ago and spent a similar amount of money. Here are my suggestions. (I would personally go with only one 4870 unless you are gaming at ultra-high resolutions). And just like georgy said I would just get one card for now, and get higher quality components for the rest of the list and then get another graphics card later. Btw what resolution do u wanna game on.
Reply to MoeDaKilla
- 0 +
Then this build would be fine
cooler master http://en.wikipedia.org/wiki/Cooler_Master cm 690 ~85$
4 gb ddr2 http://en.wikipedia.org/wiki/DDR2_SDRAM 800mhz (corsair xms2 dhx ) ~80$ after mail rebate
corsair 650tx power supply ~90$ after mail rebate
Total: ~960$
Add to that a monitor and speakers of your choice for ~240$
Reply to georgy
- 0 +
Total: ~980$
This one is perfect IMO, nice job. You don't want the P5Q because it would hurt GPU speed in Crossfire, so go with X38 or X48.
http://www.tweaktown.com/articles/ [...] index.html
Maybe a 640GB WD6400AAKS for a few bucks more than the 500GB Seagate.
Add an Acer 22" monitor for $220.
http://www.newegg.com/Product/Prod [...] 6824009094
OK, now you're out of cash and still have no speakers, burner, mouse and keyboard. Try to find another $100 or so for them. Maybe get half of the RAM and that Xigmatek later to save some cash, if that's really necessary. (The $190 E8400 is retail, it comes with a HSF.)
Reply to aevm
I'll probably be gaming at 1680 x 1050.
Reply to matt2012
Matt,
The last bit of advice I would give you is to take all this info and do a little research. Each one of us have our own preferences based on past experience so take some of the comments/suggestions with a grain of salt. for example, I recommended the Asus P5E mobo (X38/ICH9 chipsets) because I have one and have a Gigabyte X38-DS4 and prefer the Asus. there's not a lot of difference between the two but the one I picked for this build is an excellent value (I'm old) and I prefer the the BIOS and tools from Asus.
You can realistically spend the next two months researching this stuff so my suggestion would be do a final build (use newegg's "wish list" ), spend a day researching the parts then buy. You should be able to find reveiws and articles about each part on this web site or on newegg. I personally prefer the newegg reveiws because they are from every day users with issues you will have to face when building your system.
p.s. don't go for the E7200 cpu. You might be able to OC it over 3 mghz but it still drops the FSB from 1333 to 1066 and the cache from 6mb to 3mb.
Message edited by mexpedip on 07-02-2008 at 09:40:53 PM
Reply to mexpedip
Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help on $1200 build
There are 570 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
