the IDE vs ACHI mode is dependent on the type of hard drive you have and the OS you are running.
seeing as you are running SATA drives, I'd say go with ATA (if that's possible, it should) if you are running XP and go with ACHI (for Vista and higher)
now this also depends on what mode it was set on originally as well.
As far as the actual imaging, can you give a little more info like is it going to a CD or DVD. Is the drive external or internal. Did you set compression? if so was it high or fast?
The machines I ghost at work can vary in speed from 400-700mb/min. I get around 200 if I have to do it off of my external.
ATA? The three settings are IDE, AHCI and RAID; ATA is not one of them.
200MB/minute is about 3.3MB/s which sounds like its using PIO mode. Focus your energy here; check if Windows is using PIO transfer mode as well. Replace the cable to be sure, make sure DMA mode is enabled in the BIOS. IDE mode should be fine though it shouldn't cause performance problems of this kind.
------------------------------...man will occasionally stumble over the truth, but usually manages to pick himself up, walk over or around it, and carry on.
Reply to sub mesa
