Tom's Hardware > Forum > Overclocking > CPUs > Help on voltage 4 the q6600
Forum Overclocking : CPUs - Help on voltage 4 the q6600
i dont no what safe voltages to put 4 my cpu @ 3.6ghz. its currently at 1.5
q6600
gfx is 2x GTX260
850 watt psu
asus p5nd mobo
Sponsored Links
That depends on what your tests have shown: has your setup proven stable?
Also, you can search through this forum for topics on the Q6600. There are lots, given the CPU's popularity in terms of overclockability.
Reply to TonCharr28
- 0 +
http://www.tomshardware.com/forum/ [...] ture-guide
Includes thermal management and voltage limits.
1.5 volts is Intel's recommended maximum voltage for 65 nm Core2's.
What kind of temperatures are you getting?
Message edited by jsc on 07-07-2009 at 03:51:39 PM
Reply to jsc
ummmm. im using the real temp thing. and i dont believe the temps are correct. they r way too low and r sitting between 25 to 35 degrees for all the cores.
Reply to deano241092
There are 1095 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
