Tom's Hardware > Forum > Storage > Hard Disks > External Hard Drive Connection Transfer Rates
Forum Storage : Hard Disks - External Hard Drive Connection Transfer Rates
What is the fastest external hard drive connection (eSata, ethernet, firewire 800m)? I need the fastest possible read and write transfer rate connect to my laptop. What external enclosure/packaged external drive would you recommend with that type of connection? I've tried eSata and it didn't seem much faster then firewire 400 transfer rates when I did a write test. eSata is also giving me problems connecting on my laptop with XP and PC with Windows 7. Are there drivers I may be missing for eSata?
Thanks,
Aundre
Sponsored Links
In order of transfer speeds.
Ethernet
eSATA
Firewire
USB
Each of these also has a few different protocol speeds and versions but on average the above applies.
Reply to TheViper
Thanks viper. It's what I suspected but wanted to verify. Hopefully ethernet will be more reliable for me that the eSata was.
Reply to djdeluxe
From my recollection of tests, Firewire 400 and eSATA are similar, but Firewire 800 (aka IEEE 1394b) is quite a bit faster. However, getting that interface on a laptop and an external drive may be hard.
I recall that many of these tests used SATA II drives inside the external cases and that certainly helps, especially for eSATA connections from case to computer, because there is almost no time consumed in converting one communication protocol to another. However, I do NOT know whether similar data transfer performance is obtained if the drive inside the case is IDE (PATA).
Reply to Paperdoc
There are 1014 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 ifko_pifko won the Freshman badge
  • 01:00 Riser won the Spy badge
  • 01:00 spud won the Spy badge
  • 13:27 evongugg won the Sophmore badge
  • 01:00 gtvr won the Freshman badge
  • 01:00 Tech30 won the Freshman badge
  • 01:00 batuchka won the Freshman badge
  • 01:00 copfrance won the Freshman badge
  • 11:24 2shea won the Sophmore badge
  • 01:00 alexreynolds won the Freshman badge
