Tom's Hardware > Forum > Graphic & Displays > ATI > ATI 4870 and Antec EA-650 power question
Forum Graphic & Displays : ATI - ATI 4870 and Antec EA-650 power question
Hi,sorry if this is a noobish question but I want to make sure I power the 4870 correct. I am using one ATI 4870 and need to know which power supply pins to send to it.This system will not be using crossfire.
The ATI 4870 has two 6-pin inputs.The CPU has one 6-pin and one 8-pin pci express wires. How do I configure this setup?
Thanks!
Sponsored Links
You must be a cpu enginneer if your cpu has 6 pins. Most of them have around a hundred pins. :) If you mean the cpu power connector, it's either 4/8 pins. No 6.
The 6 pins from the PSU is for PCI-E. Plug two in the GPU. If not enough cable, then use the bundled power cable adapter/splitter.
Reply to akhilles
There are 1110 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
