News
Warner warms up to YouTube with media sharing agreement
Warner Music Group (WMG) and YouTube today announced a joint partnership in which Warner will distribute its copyrighted content through the increasingly popular video sharing site. Warner is the first company to announce support for YouTube's new "content identification and royalty reporting" system, which YouTube says will be generally available by the end of the year. Read more
CD emulators may utilize rootkit-like stealth to circumvent DRM
Mark Russinovich, the security software engineer who discovered the presence of stealth techniques to mask the presence of digital rights management drivers in Sony BMG audio CDs, announced this morning he has discovered rootkit-like stealth in two popular brands of CD emulator software. Read more
No DRM for Prince of Persia PC
A post over on the Ubisoft forums states that the PC version of Prince of Persia 2008 shipped without DRM protection. Read more
Microsoft Speaks on Windows 7 Technical Bits
As much as the new features of Windows 7 appear to be tailored to improve the end-user experience, Microsoft still needs to consider the corporate environment. Read more
Latest Reviews & Articles
Reader's Voice: An Introduction To Home Automation
Perhaps you've heard about Bill Gates' remote-controlled home and thought to yourself that the technology to automate your own home was decidedly out of reach. Today, Tom's Hardware reader John Knutson walks us through what it took to get his home wired. Read more
Perfect Notebook Storage: Seven 2.5” 500 GB Drives
We compare the latest 500 GB notebook drives from Fujitsu, Hitachi, Samsung, Seagate, Toshiba and WD. Seagate is first manufacturer to reach 500 GB at 7,200 RPM, but which is really the best drive? We loaded up our updated test system to find out. Read more
Mainstream Graphics Card Roundup
You don’t always need the fastest graphics card around. For somewhere between $135 and $235, you can game like crazy in DirectX 10 without a problem at 1920x1200. We test and compare five graphics cards from this mid-range price segment. Read more
USB 3.0 Ups Peripheral Bandwidth
The new USB 3.0 interface is just about ready. It'll accelerate throughput from the 480 Mbit/s of today's USB 2.0 to 5 Gbit/s, which is important for storage and peripheral devices. But USB 3.0 also introduces power saving options. Read on for more. Read more
All the Reviews & Articles
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > My new system will not post. please help.
posted over at anandtech but no response yet.
okay. so i was going for a budget gaming pc and i had bought everything i needed:
AMD Athlon64 X2 5000+ Black Edition
Thermaltake SopranoRS Case
Antec Earthwatts 430W PSU
Wintec AMPO 2x1gb ddr2 800
150gb Seagate Caviar HDD
Phillips DVD burner
XFX Geforce 8800 GS XXX alpha dog yada yada yada
GIGABYTE GA-MA78GM-S2H Mobo
CoolerMaster Hyper TX2
i put everything together and connected all the power cords and turned it on.
everything spun up correctly but the monitor would show nothing.
the little yellow light never turned green.
i'm using an old Dell CRT from the previous pc that we had.
the HDD worked, i could hear it spin up.
the DVD bay worked, i could open it up.
the cpu cooler, system fan, and video cards all worked because i could hear or see their fans.
but the system wouldn't post.
the thing is, this case didn't come with a case speaker and the old dell that we had used a series of lights on the I/O panel to indicate problems so i don't have any idea as to what the problem could be.
gigabyte said that i should RMA both the processor and the Mobo because i had no way to isolate which of the two it could be.
so i did.
and i waited two weeks for the new hardware to come in. after installing it yesterday, the same thing happened. the same exact thing.
i'm going to take it to the shop tomorrow and see if i just made a bonehead move while installing everything but i figured since they're closed today that i could post here and maybe find some sort of solution so i wouldn't have to worry about going to town.
please, if anybody has any sort of advice or solutions, do not hesitate to lay them on me.
the motherboard has an onboard speaker apparently because if i put in the gfx card w/o the 6-pin cord plugged in, it gives me the long beep to tell me that the card isn't installed correctly.
i unplugged the dvd drive and the hdd and have tested both sticks in all 4 slots but still nothing as far as the display goes.
if i plug the 6-pin back in then i get no beeps which is supposed to mean that there is some kind of board, cpu, or psu problem, right?
is it possible for only one of the 12v rails to go bad?
because everything else gets powered up.
i will try to make sure that the cpu is lined up correctly but i really hope gigabyte didn't send me another board DOA...
cpu is lined up right.
i'm out of ideas.
i've tried putting either stick in each slot one at a time and tried booting to no avail.
i've tried hooking up monitor to mobo and gfx card.
i've tried using the dvi to vga adapter for all dvi ports.
i've tried using all vga ports.
i've tried unplugging everything and booting.
i don't know what to do.
Message edited by zakatak on 07-04-2008 at 10:57:43 PM
Sponsored Links
Have you plugged in the 4/8 12v CPU power connector from the PSU to the MB?
Reply to badge
- 0 +
I know this probably isnt the most educated response you are likely to get but are you sure that your DVI/VGA cable to your monitor works?
Reply to Abhik
- 0 +
I recently saw a faulty cable being the issue with a no-POST on this forum, so definitely try to check the cable. Also, that 4-pin ATX power often messes me up when I first build. I never remember it.
Also, try a single stick of RAM at a time. (And switch out if one doesn't work).
Reply to zipz0p
- 0 +
You should have tried to POST to BIOS with CPU/HSF, 1 DIMM RAM and the video card only. Unplug everything else.
Message edited by badge on 07-05-2008 at 12:04:27 AM
Reply to badge
-Check VGA cable
-Check monitor brightness (don't laugh, it happens)
-Check CMOS Jumper
That's what I can think of now, might try a different monitor/cable, if possible.
Reply to Murissokah
- 0 +
cleared cmos.
i did what you said badge.
yes the 4-pin is plugged in.
i did the single stick at a time deal.
the monitor works on the old system which i'm working from now.
...no post.
Message edited by zakatak on 07-05-2008 at 12:43:55 AM
Reply to zakatak
- 0 +
If your broke the system down to CPU, 1 DIMM RAM and video card and get nothing, you know it's one of those elements or the MB. You would have to have spare parts and start swapping out video card, CPU, etc.
Try this. Be sure the system has a working speaker connected to the MB speaker header to allow audible BIOS beeps. Take out ALL the RAM. Boot the system with no RAM. If you do not hear the MB beep signifying there is no RAM in the system, you likely have a bad MB. The CPU is suspect also.
Reply to badge
- 0 +
i'll try. this is what i did last time.
hopefully i don't have another DOA gigabyte board.
this could be the end for gigabyte boards with me.
Reply to zakatak
There are 841 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
