Tom's Hardware > Forum > Homebuilt Systems > New System Build > New system build - Your input please.
Forum Homebuilt Systems : New System Build - New system build - Your input please.
Hi Everyone,
The time has come again to put something new together from scratch. The old system is on its last legs. I am not entirely a hardware geek but you guys have helped a lot in my decision-making process. So first of all, thank you for all the helpful posts!
Here is what I came up with thus far for my new rig. Intended use is for gaming including OCing. I would really appreciate if you could give your thoughts about this or if you see any problems that this build might run into.
Thank You!
Message edited by Rup on 07-05-2008 at 12:53:07 AM
Sponsored Links
Looks okay.
This is the same card but cheaper, http://www.tigerdirect.ca/applicat [...] CatId=3585
You can get some of the above items cheaper at Infonec (www.infonec.com)
Message edited by Shadowthor on 07-05-2008 at 01:16:33 AM
Reply to Shadowthor
- 0 +
1- ASUS P5Q Deluxe is a better mobo
2- HD 4870 is better than 9800 GTX
3- mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 is better than your choice
4- Western Digital Caviar SE16 WD6400AAKS 640GB is a better hard disk
Good luck
:hello:
------------------------------ LianLi PC-A70 Case/Enermaqx Galaxy 1000W/Asus Rampage Formula/E8500/Thermalright Ultra 120 Extreme Lapped/Scythe S-Flex SFF21F/Crucial Ballistic Red Line DDR2800 PC6400(2X2)GB/8800GTS 512MB/WD Raptor2X150GB/ViewSonic VX922(1280X1024Max)
Reply to kad
kad hit everything right on the head.
4850 is better than 9800GTX in some cases. Same price too. Go with the 48x0 series.
4850- $192 CAD
http://www.directcanada.com/produc [...] POWERCOLOR
4870- $311 CAD- Smacks 9800GTX around- competes with 260 & 280.
http://www.directcanada.com/produc [...] e=SAPPHIRE
Message edited by shadowduck on 07-05-2008 at 02:34:59 AM
------------------------------ http://www.tomshardware.com/forum/ [...] ate-modode <-- Computer Builds
Success comes from knowing that you did your best to become the best that you are capable of becoming."-John Wooden
Reply to shadowduck
- 0 +
Thanx for the creative input!
What about the PSU? 700Watt going to be enough?
Reply to Rup
Overkill for just 1 card.
If you want CF later- it is good to keep.
Reply to shadowduck
There are 475 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
