Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Comp wont turn on after installing water cooling
Forum Overclocking : Cooler and Heatsinks - Comp wont turn on after installing water cooling
hi, i have a P5K SE Motherboard, with c2q q9550 cpu. after installing water cooling, pc wont turn on. Fans does spin for a half second, if i dont plug the 12v rail everything works fine. I've checked theres no leaks and defective hardwares, cpu pins in good condition.
please help
Sponsored Links
CPU block isn't seated correctly and shutting down due to thermal? Are you sure your pump is powered and pushing coolant? If it isn't cooling your CPU, a waterblock isn't a very good passive cooler.
What WC setup did you install?
Reply to rubix_1011
WC Cooling parts are custom made, bought it from a pc shop. Tested without the wc pump turned on, fan attached, but no avail.
Reply to fortuneflyer777
Custom made...meaning what? Actually designed and milled, or just 'chosen' and installed?
Reply to rubix_1011
it's not like a set, i bought them piece by piece, With their own logo on top of the cpu waterblock
Okay, lets get past the 10 questions. Please post the list of parts you bought, and post pics of the setup.
You probably mismounted something, have massive air in the loop, or some other issue. Since you bought the parts from a real store I guess they should be able to help you out hoprefully.
Reply to Conumdrum
^Exactly...let's hop straight to the problem...give us the details first.
Reply to rubix_1011
OK, heres couple of pics of my setup...
http://img36.imageshack.us/img36/5184/img0854v.jpg
The pump
http://img216.imageshack.us/img216/3601/img0857d.jpg
Radiator
http://img158.imageshack.us/img158/6683/img0855d.jpg
http://img208.imageshack.us/img208/3025/img0856b.jpg
I bought:
A chinese made pump
Radiator
CPU waterblock
T shaped plastic thing?! attatched with the outflow tube (don't know what it is)
No water bottle, i used plastic tube instead
Message edited by fortuneflyer777 on 07-09-2009 at 07:15:05 AM
I give up. Best of luck.
CPU waterblock. Made by Bob? Fred?
Pump. Nice if you gave a link so we could look at the specs.
Fans? Ambient temps?
You prolly installed it wrong.
Reply to Conumdrum
waterblock: made by OCQQ www.ocqq.com
Pump: Jingway DP-400 [url=http://www.jingway.com.tw/en/products.html][/url]
I need to know it is something to do with the MB or PSU?
Thanks for help
OK, so i've just tested the power with my multimeter, psu power runs fine but the mb atx12v power plug was fried :o , and some parts were running hot
Yay...your pump probably was crap and pulled too much and burnt your PSU. Way to buy cheap junk.
Reply to rubix_1011
- 0 +
I would recommend buying a pump with external power, that way you don't have to use up power from the PSU. Unless you want to buy a new power supply with high wattage and amps, and that would cost a nice sum.
Reply to videl
There are 1144 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
