Hi i was wondering what are the best settings to overclock my system using the stock fan.
Asus P6T mobo (non-deluxe)
Intel i7 920
4GB DDR3 1333MHz Ram
HD 3870 X2 1G
CoolerMaster Full Tower Case (good air flow)
I was hoping to get around 3Ghz -3.2GHz just using the stock Fan. I am getting around 30C ATM on idle. I am mainly wanting OC When I am Rendering 3D so it will be quicker.
BTW i have never really OC any Pc's before so i am a bit noob at this
For that low of an overclock, just set the BLCK in bios to 140-160 (I think). Leave everything else AUTO. There is more you can do (like manually setting voltages low) but if you're looking for a fast and dirty, try that.
There is a great discussion on the ASUS boards for the P6t Deluxe (not the v2 board, the old one). He has all the settings at very speeds (except voltages).
