Tom's Hardware > Forum > Graphic & Displays > ATI > IIyama 511S problem
IIyama 511S problem
Forum Graphic & Displays : ATI - IIyama 511S problem
Since a few days when i put my IIYAMA 511s on, he is going directly in standby mode, even with or without signal, and i can not get hem on. Who knows what the problem can be?
BrunoS
Sponsored Links
I've seen several LCDs at the hospital I work at do that (although these were a different brand) Sometimes they have to be sent back, but in many instances I have to perform a reset by holding down two of the buttons as I'm turning the LCD on. It'll be different for every monitor so either you need to look this information up online or give the manufacturer a call. That won't DEFINITELY solve your problem, but it'd be a good start.
Reply to rodney_ws
- 0 +
I had that problem before and couldn't figure out what was wrong - it turned out that my video card disabled my monitors and decided to output only to my TV (I have 2 monitors and S-Video cable plugged in at all times, with my Iiyama 24" as my main and using either a 19" monitor beside it or my TV on the other end of the room as a secondary)
Took me forever to realise it because I never thought to turn on the TV. Maybe something similar happening there?
Just my €0.02
Reply to Kraynor
There are 1167 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
