Tom's Hardware > Forum > CPU & Components > CPUs > Low power consumption
Forum CPU & Components : CPUs - Low power consumption
Put this in the CPU section, but it could go in PSUs too, so apologies if anyone thinks I've hit the wrong section...
I'm trying to put together a home-built NAS, and I've already asked a load of questions about this, but I still have more! Basically, it looks like the best solution for me is a PC, probably running Linux, with a dedicated RAID controller and not much else. To that end I'm looking for information on the lowest possible power consumption that I can put together.
I don't need a multicore processor, nor do I need much in the way of performance. The motherboard will not need to support much - the RAID controller running on PCI, a gigabit NIC, a flash drive for the OS and that's pretty much it. I'd like the most efficient power supply I can, and I'd like every power-saving facility that I can - wake-on-lan, for example. Essentially, I want to have this thing running all the time and consuming as little power as I can possibly get away with. Low power consumption is much more important than budget. Ideally, it will be passively cooled, but that isn't a requirement.
There seems to be very little information out there about minimising power consumption. Can anyone help point me to some resources? Or give me suggestions for hardware to look our for?
Sponsored Links
For really now power consumption you probably want to go with an AMD cpu as the intel chipsets burn through some power from what ive seen.
Something like this
http://www.newegg.com/Product/Prod [...] 6819103197
with a mobo to suit should be fine.
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
Thanks Chookman...
That's still a 45W processor, though. I was thinking more along the lines of a mobile processor - the Intel Core Duo U2400 draws 9W (TDP) and the Intel Core Solo U1400 draws 5.5W (TDP). I'll need to dig around to see if I can find these...
Has anyone got any other suggestions, no matter how off-the-wall they are?
Cheers - Adam...
Reply to adam-the-kiwi
In that case you could try an Intel Atom or the new AMD's that i havent seen around yet.
Article on toms here
http://www.tomshardware.com/review [...] ,1997.html
Reply to chookman
Nice one Chookman - that looks very useful.
Are there any other, even lower power systems out there to consider? Even the Athlon system outlined in that review uses nearly 40W idling. I probably wouldn't need much more than a mobile phone processor to drive a RAID controller and a gigabit ethernet controller, would I?
Thats 40w for the entire system, you arent going to get much lower than that even with a notebook (Atoms are being used in the Eee PC's) VIA also make some low power chips dont know how they stack against AMD or Intel though.
Reply to chookman
There are 1130 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
