First System Build Need Help & Suggestions
Last response: in Systems
Case: Sunbeam Transformer IC-TR-SV Silver Steel ATX Full Tower Computer Case 80
CPU: Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 210
Motherboard: EVGA 123-YW-E175-A1 LGA 775 NVIDIA nForce 750i FTW190 190
GPU SAPPHIRE 100243L Radeon HD 4870 512MB 256-bit GDDR5310 310
PSU Rosewill RX950-D-B ATX12V v2.2 & EPS12V v2.91 950W 155
Memory G.SKILL 4GB DDR2 SDRAM DDR2 800 (PC2 6400) 85
CPU Cooler ARCTIC COOLING Freezer 7 Pro 92mm 32
Hard Drive Western Digital Caviar SE16 500GB SATA 3.0Gb/s 80
DvD ROM LG 20X DVD±R Super Multi DVD Burner 24
Total: 1166
Links:
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CPU Cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Hard Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
DvD ROM: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
I wouldnt recommend that psu. Look at this http://www.tomswiki.com/page/Tiered+PSU+Listings ... i suggest PCP&C 750w or corsair. Here is a better cooled case http://www.newegg.com/Product/Product.aspx?Item=N82E168... . I would change the cpu cooler for a xigmatek if you plan to overclock. This motherboard is sli and you want crossfire (?)... i suggest you get this one http://www.newegg.com/Product/Product.aspx?Item=N82E168... .
Good luck with your build ;)
Related ressources
Sorry i gave you the wrong link.. i was talking about coolermaster 690 without psu. You better get a 750w from a good brand if you want to crossfire one day. The gigabyte motherboard would be great for crossfire.
Take a corsair 750tx power supply, you will save 45$. Put this cash on the gigabyte motherboard ;)
Ask the community
