OKay guys, Im sure there is a very simple solution here but I just cant find it.
I have a SB Fatality soundcard and I think I have wired it up correctly with the jacks. However, when I go to the THX Setup Console to test and run the 'speaker selection' check etc I have the front right and rear right 'ladies voice' sounding out of the front left and rear left speakers (or rather, my 5.1 headphones). The sub and centre are fine.
What am I doing wrong. I have swapped the jacks but to no avail. Is there a wa to 'swap' the speaker configuration. It's annoying because sounds that should be coming from the right hand side come from the left
Please help me with this frustraing issue.
Thanks
Thanks
