+1 on psu change
use that money to up your cpu
hdd - wd 640gb is only $5 more. well worth it.
if you add another gpu isn't in on x4 for the p35? you can get the p5q p45 board for about the same price and that would be x8 for the 2nd card.
pc power and cooling is one of the best brands of psus that you can get. top of the line. corsair also makes an excellent 750w psu.
the p5q is a great p45 board.
cpu - well you said you want it for cad. i think first you need to figure out with the psu and mobo changet how much $$ you have for the cpu. it would be great if you could get the q6600 but i think it might be too much. that quad would be great for CAD and it is a good overclocker.
I read somewhere that the 7200 overclocks better than q6600 which is 70CAD more. Off-course q6600 is better but will 4 cores be of any help at this point in time?
I guess in the next 2 years there will be more applications that will take advantage of the 4 cores.
Message edited by xpix on 08-26-2008 at 09:12:28 PM
^No. Quad won't help much with a gaming system (except for FSX and a few others). For CAD (ie SolidWorks, I use it btw) it will help quite a bit. (btw, do you mean Canadian $ or Computer-aided design? By looking at your prices I'm assuming you are Canadian? If you are US you CAN find better stuff for smiler price)
My recommendations:
Unless you plan to CrossFire or upgrade to a 4870X2 a PC Power & Cooling 610 is a good choice. The Enermax (see: http://www.xtremesystems.org/forum [...] p?t=108088 )is a top brand PSU but kind of too much money.
Getting a P45 would also help. +1 for the WD AAKS 640GB also.
Message edited by Shadow703793 on 08-26-2008 at 09:27:48 PM
Place any money saved into this dual core, Dont get a quad for your gaming rig.
$230
Intel Core 2 Duo E8500 Dual Core Processor LGA775 3.16GHZ Wolfdale 1333FSB 6MB
http://www.ncix.com/products/index [...] ture=Intel
I am Canadian too, Edmonton Where are you? lol taxes in EDM are only %5
1) move to Alberta for lower taxes
2) get job on the rigs makin 80k starting
3) buy a QX processor hehe
