------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
First, you don't need a CF motherboard to run the x2. The point of the X2 is to give you CF, without a care about what motherboard you have. Second, before getting the second 8800GT, make sure your PSU is up for powering both of them. It probably is seeing as the 8800GT doesn't use a lot of juice.
If you already have an SLI board, get the second 8800GT. This will nearly give you the power of the GX2, which is >~ the 4870. (the 4870x2 would probably be a faster option then your 8800GT SLI setup, but you are only at 1600x1200, so its not really needed. Save the dough.)
------------------------------The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
If an 8800gt sli is somehow equivalent to a 9800gx2, then I'll get another one.
Yet I was thinking about getting two 4870x2 in a crossfire setting and wait for the new nehalem processors to come out which would be a full system upgrade.
Message edited by Anonymous on 07-24-2008 at 02:43:15 PM
The 9800GX2 is basically two 8800GTS/9800GTX cards facing each other. The 8800GT has a few less stream processors, so it will be a bit slower.
Considering the price of the 8800GT, and the fact that you have one already, you can get ~75% of the power of the 9800GX2 simply by buying a ~$100 card. Is that sweet or what?
You'll have to get a new motherboard, RAM, and CPU if/when you switch to Nehalem. The only thing I'd worry about moving over to a new system is the case and PSU. (and pray you don't need a new PSU...) Seeing as you already have the SLI motherboard and an 8800GT already, buying another is a good move.
Always a DEMON!
Reply to 4745454b
