Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Phenom II 940 Water Cooling
Forum Overclocking : Cooler and Heatsinks - Phenom II 940 Water Cooling
i Was wondering what would be a good watercooling solution to put in the p183 that would give me enough headroom to overclock my 940 to 4.0-4.2ghz with decent temps.
Sponsored Links
This would be a good start, Better to know why before you buy.
Guides
http://forums.extremeoverclocking. [...] p?t=282232 Pretty up to date info and buying guide
http://gilgameshreviews.com/index. [...] s&catid=40:overclocking-and-cooling&Itemid=86 Another good guide
http://forums.extremeoverclocking. [...] p?t=312743 What to do once all the stuff is in the door
http://www.xtremesystems.org/forum [...] p?t=223835 Many build logs on MANY cases, great learning tool.
My latest rig:
http://www.ocforums.com/showthread.php?t=604016
Forums
http://www.xtremesystems.org/forums/index.php? Not a noob site, but great stickies
http://www.ocforums.com/ My fav, good peeps, know their stuff, less hardcore
http://www.over-clock.com/ivb/inde [...] opic=20277 A GREAT Europe site
http://www.overclock.net/water-cooling/ Decent site
Tests on equipment, not reviews, truly scientific tests
http://translate.google.com/transl [...] n&ie=UTF-8 Info on rad testing
http://www.xtremesystems.org/forum [...] p?t=220593 More rad testing
http://skinneelabs.com/ Host for Martins lab and some newer tests
http://www.skinneelabs.com/MartinsLiquidLab/ Test results, very technical
Stores
http://www.dangerden.com
http://www.petrastechshop.com/
http://www.sidewindercomputers.com/
http://www.jab-tech.com/
http://www.performance-pcs.com
Reply to Conumdrum
Thanks I'll check out those sites.
Reply to lightning099
Since this is my first attempt at watercooling i was wondering if buying a kit would be more advantagious instead of buying individual parts. the kit i looked at was the H20-220-APEX ULTRA from swiftech. is this kit worth the money or would i be better off building my own.
It's a very nice kit, quality stuff. It's not a per say 'kit', it's a smart collection of various parts from quality manufactuers that can be bought in seperate parts.
It's good stuff and plenty enuff to cool any CPU on the market.
You still need to learn about install tips, bleeding and maintenance, so all those links I posted are just as important as you buying seperate parts.
Reply to Conumdrum
Thanks. For the money is it worth it to buy the kit or would it be a lot cheaper to assemble one from various parts.
All depends what you need. That is where a few weeks of perusing the links, forums etc will make up your mind. Going watercooling isn't as easy as buying a new DVD at Best Buy.
The task is back in your lap.
Reply to Conumdrum
There are 462 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
