Latest Reviews & Articles
Overclocking Core 2 Duo: Power Versus Performance
Intel's fastest Core 2 Duo, the E8600, runs at 3.33 GHz. But if you're a performance-hungry power user, we found that you can actually increase the chip's efficiency by overclocking it, thanks to 45 nm manufacturing and plenty of built-in headroom. Read more
Life At 2 GT/s: 6 GB DDR3-2000 Memory Kits Compared
Memory vendors put a lot of effort into drumming up excitement over high-end memory kits, but many of those products turn out to be vaporware. We test six DDR3-2000 kits that enthusiasts can actually buy today, and push them as far as they'll go. Read more
DDR3 Memory Scaling On AMD's Phenom II X4
DDR3 memory is available in speeds ranging from DDR3-800 to DDR3-2133. Which is the best memory choice for AMD’s Phenom II X4? We tested as many speeds as possible using aggressive and conservative timings to find the sweet spot for your next build. Read more
Intel Core i7-975 Extreme And i7-950 Reviewed
Today Intel launches two high-end processors that take the place of its i7-965 and i7-940 CPUs. More speed? Same price points? We’ll take it! But are the new chips compelling enough to warrant spending more than you would on an i7-920? Read more
All the Reviews & Articles
Tom's Hardware > Forum > Home Theatre > HDTV > Samsung TX-R3080WH - no 720p - problem?
Archived from groups: alt.tv.tech.hdtv (More info?)
I'm thinking about getting the Samsung TX-R3080WH over the Sony
Widescreen FD Trinitron® WEGA® HDTVKD-30XS955 - both
flatscreen/widescreen CRT's with HD and comparable features. I think
the Sony's picture is slightly better than the Samsung, but the depth
of the cabinet (or less depth) of the Samsung has me sold.
My concern is that the Samsung does not process 720p as part of its HD
capability. It does process 1080i and 480i and 480p.
Does this mean that if the broadcast is in 720 I have no HD capability?
Is the contest settled between the two formats in the industry? Will
there be a 1080p eventually, making a set like this obsolete? Should I
insist on a set that has both 720 and 1080?
Thanks in advance,
LG
Sponsored Links
I owned the TX-R2678WH and have returned it to get the larger
TX-R3075WH HDTV Samsung set. I can tell you that it does all of thoses
aspects.
480i/480p most of the analog air channels and standard definition
digital channels are in this format, it also accepts Progressive scan
DVD playback.
720p most of the primetime FOX, UPN, and ABC shows that are in HD are
in 720p, and they look stunning.
1080i some of the primetime CBS, NBC shows are in this aspect they look
nice too but in a different way.
Reply to Anonymous
- 0 +
Since this set has a built in tuner the lack of 720P input capability
wouldn't be a problem.
Unfortunately there's no way to avoid a set going obsolete. There will
,however, never be a 1080P that is broadcast.
"LG" <clgavel@acadiacom.net> wrote in message
news:1127664174.154725.24870@f14g2000cwb.googlegroups.com...
Thanks in advance,
LG
Reply to DJ
"dj" <nospam@nospam.com> wrote in message
news:__ydneTTcZtm2qreRVn-sg@scnresearch.com...
Uh, dj, you might want to do a little homework before making statements like
that one. It is entirely possible that we could see 1080p broadcast at 24
or 30 frames per second. Not likely that 1080p60 will ever be broadcast is
likely what you meant to say.
Leonard
Reply to Anonymous
There are 838 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
