You won't see all 4G, but you should see ~3G+ depending on how much RAM your video card has. Try pressing Ctrl + Alt + Delete and click on the performance tab. Look at Total Physical Memory at the bottom right. That is how much RAM that XP sees.
gorrath, I think you would know if yo have XP 64 Bit operating system.
I have Win XP 32 Bit with 4 gigs of Ram. Task manager under performance shows I have 3.4 Gigs available for program use, this is a X4870 Grphics card with 512 megs of Ram.
3.2 to 3.6 Gigs out of 4 gigs installed is typical. Users with high end (1 gig VDRAM) and depending on I/O devices usually run 2.8 -> 3.2 Gigs. May need to change memory allocation in BIOS.
Edit - I see Zorg Beat me to it will I was typing.
Message edited by RetiredChief on 09-26-2008 at 05:47:57 AM
Slot 'DIMM_1' has 1024 MB (serial number F32C9A5B)
Slot 'DIMM_3' is Empty
Slot 'DIMM_2' has 1024 MB (serial number F32C9A9E)
Slot 'DIMM_4' has 2048 MB (serial number 252700FC)
Message edited by gorrath on 09-26-2008 at 05:50:20 AM
Your problem is not the addressing problem that is related to the 32bit OS. I believe your problem is related to the 2GB stick that you put in the 4th slot. It may be related to the max of that mobo. I would say not but it is a Dell and OEMs have been known to pull crap like that. You can call Dell and ask them the max of the mobo and slot. You can try the 2G stick in slot 2, and then try a 1G stick in slot 2. The mobo may also only be able to take one gig sticks.
Someone told me it could because you're supposed to put stick in pairs, is that true?
No, it's probably the 2G stick. As I said, try a 1G stick in slot 2. You can put two additional 1G sticks in, but then you will be limited by the 3G barrier. You will probably get ~3.25G so the last stick will only give you a little. The only reason to have them in pairs is to enable dual channel operation. The gain from this is nothing to loose sleep over. Just add one stick to slot 2 and move on.
This is NOT a 3.25 problem. He had 2GB. He put 2GB in. He still has 2GB, not 3.25.
I'm guessing the mobo has a limit on the amount/type of RAM it can take. Try the 2GB stick by itself and see if you can even boot. If not, than its something with that particular stick on that particular mobo.
