Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > How much power do I need? Which one?
Here are the components for my new PC with wattage requirements:
MB: Asus P5Q-E
---WATTS: 500-600w recommended per documentation if using 2 pcie cards
CPU: Intel Q9550
---WATTS: 95w at max
GPU: 2 x Sapphire ATI 3650's (I use 3 monitors for trading)
---WATTS: 550w or higher recommended per ATI docs for 2 cards
---Separate power connector not required for these cards
Mem: 2x2gb Corsair XMS2 DHX DDR2 800 (the ones w/ the large heatsinks on them)
---WATTS: Unknown, i'm guessing 5-10w max each, but I have no clue really
Hd: 2 x WD640gb
---WATTS: 10w at peak each, total of 20w
Fans: Probably 1 120mm intake + 1 120mm exhaust + CPU fan (not counting psu fan + ati fans)
---WATTS: Probably around 3-5w each, so around 15w total
Case: TBD (after picking all components, will pick case to fit them all)
Usage:
-No overclocking
-No gaming
-Mostly trading (for a living) across 3 monitors + home video editing + basic web/email/etc.
Question:
-So should I go with a 650w supply? 750 to be safe? Any brand recommendations?
Tnx!
Sponsored Links
You need a power supply with 25 amps on the 12v rails.
This will be fine or choose an AMD certified power supply for Crossfire, even though you are not doing Crossfire.
http://www.newegg.com/Product/Prod [...] 6817139004
Top Tier PSU:
http://www.tomswiki.com/page/Tiere [...] ngs?t=anon
http://www.xtremesystems.org/forum [...] p?t=108088
http://www.anandtech.com/casecooli [...] spx?i=3359
http://www.eggxpert.com/forums/thread/323050.aspx
http://www.jonnyguru.com/forums/showthread.php?t=1460
Silent PSUs
http://www.silentpcreview.com/article699-page1.html
AMD Certified PSUs (Single+Crossfire):
http://ati.amd.com/online/certifiedpsu/index.html
Certified SLI-Ready Power Supplies
http://www.slizone.com/object/slizone_build_psu.html
Message edited by evongugg on 08-27-2008 at 06:10:27 PM
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
- 0 +
Given that it sounds like you'll be making a living with this PC, the high quality Corsair recommended by evongugg is an excellent choice.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
Corsair is an excellent choice and newegg frequently lists these psus with rebates and discounts making it too good to resist. I have no need to buy any other brand of psu unless its that good of a deal and the quality is there...
Reply to englandr753
The Corsair recommended is only 550w, is that good enough?
Reply to jhammer569
- 0 +
Oh yes. Your rig could probably run on a good 400W PSU; your requirements aren't very high. Manufacturers base their recommendations in part on assumptions about the rest of your system.
If that DDR2 RAM requires large heatsinks just to run at 800 speed, chances are it is factory overclocked 667 (or 533) running way above the JEDEC default 1.8V. Get this Mushkin instead: http://www.newegg.com/Product/Prod [...] 820146731.
Reply to jtt283
cool.
One more question then:
-If I get a high quality 550w or even decide on the 620w corsair, my computer will only pull the wattage it truly needs from the outlet, it just means the PSU could support (close to) 550w (or 620) if absolutely needed, but more than likely, I'll be pulling maybe 400w from the wall outlet give or take on average?
I'll look into diff. memory as well, the corsair needs to be at 2.1v to get the 4-4-4 latency from what i've read, so if 1.8v is safer/more reliable, then i'll look into that instead, i don't need overkill
Reply to jhammer569
- 0 +
+1 to 1.8v memory.
having more power than you need will not hurt anything. so if you only need 400w and you get 500 or 600w then that just gives you more room for future upgrades. but like already said 2 or 3 times get a good PSU. Corsair is a great recommendation.
Reply to bdollar
the Corsair DHX 2 800 Sticks are fast enoug, they don't have to run at 2,1 it is recommend to use 2,1v for 4-4-4 timings...
Jedec standard is 1.8 v and 5-5-5-15 latency i think.
anyway corsair is more expensive then GEIL, and my GEIL memory serves me very well. You don't have to spend more then you want. the 620 Corsair's are very reliable. I have one in my HTPC.
Reply to radium69
This is very elementary but is interesting if you read thru:
http://computer.howstuffworks.com/power-supply.htm
Last question in this thread:
Corsair 520HX vs. Corsair 550VX
Priced about the same, and it sounds like both will meet my needs as far as wattage goes.
So my question is if modular (520) is worth it, is it that much better to get the cables out of the way that I don't use, or is that just for hardcore folks who love their pc's to be neat & tidy and at frigid temp's (in which case I might as well go higher wattage w/ higher efficiency in the 550)?
Tnx. (btw, jt, tnx for recommendation, i looked & i decided that i'm going to get the mushkin 2x2gb instead at 1.8v w/o the super tall heatsinks to get in the way of everything)
Reply to jhammer569
- 0 +
mushkin will be good. have had good experiences with that brand.
Reply to bdollar
The Enermax 625W Pro82+ is pretty good. It damn quiet too.
http://www.hardwarecanucks.com/for [...] eview.html
My system is
AMD Phenom 9850
Mushkin 2x2GB DDR2
If Enermax has a more powerful PSU (in terms of watts) with the same performance of the 625W Pro82+, I'd probably get it for my next pc.
Reply to dfbreyes
There are 986 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
