Tom's Hardware > Forum > Storage > DVD/CD Writers > Lite-On Drive Problems
Forum Storage : DVD/CD Writers - Lite-On Drive Problems
I have 2 cd/dvd RW drives. 1 is an Ativa DH-3H20A which is suppose to be a Lite-on DH-20A3H clone. The 2nd is a Lite-on LH-18A1P. Both of these worked just fine when installed, but I ended up having to reinstall my copy of XP Pro due to the ICE STORM here in AR which knocked out all power for about a week. After reinstalling Windows, the drives will both read disks or can boot from them just fine, but neither will write a CD or DVD. Have tried updating firmware, and have changed write programs to just about everything I can imagine, but to no avial. Is this a case of bad drives now or is there something else I need to check? NOTE: no ability to change RMA/PIO either. Any assistance/advice with this would be greatly appreciated.
Sponsored Links
Did your computer experience any power shocks? You may want to try the drives with other computers.
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
try your drives one at a time.
If they work it may be a cabling problem. If they are IDE (ribbon cable) you can get a Master/Slave conflict requiring you either set both to CS (Cable Select) or one to Master and one to Slave (rear jumpers on your drives).
SATA drives do not have this conflict.
If you have SATA I'd still try them one at a time though I couldn't guess at the problem.
Solution 1 (for Ribbon Cables)
1) Shut down PC
2) Ensure both are CS or one is MS and one is Slave
If no joy,
Solution 2:
1) Shut down your PC
2) Disconnect all cables from BOTH drives
3) Reboot and Shutdown again
4) Hook up one drive
5) If it works or not, shut down and try the other drive
Reply to photonboy
Unfortunately I don't have another computer to try drives in, so don't know if they will work in another computer. Have already tried cables and have done the CS and the Master Slave options but no help there. I tried removing both drives as suggested, rebooted then installed only one of them, but that didn't work either. I'm about to just give up on these drives and say they must be bad. I just can't understand how they can read, boot and do everything else so perfectly and still won't write.
Reply to besteagle
There are 1297 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
