Well, my current system of 3 1/2 years has finally reached its end at a pretty unfortunate time.. I'm pretty low on funds at the moment. On the plus side, I have a monitor (22" Widescreen @ 1680x1050) and a case ready to go. I also have a 160gb HDD I can use, but it's only SATA 1.5. I've been trying to catch up in a hurry on current hardware, and this is what I've come up with so far..
Intel Core 2 Duo E7200 ($130) OC to ~3.2 ghz.. I'm new to OCing so I'll play it a bit safe
Asus Radeon 4850 HD ($195)
2xCorsair Dominator DDR2 1066 ($178 / $98 after rebate) Are there any problems with 4x1GB vs 2x2GB other than upgrading in the future?
Arctic Cooler Freezer 7 Pro CPU Fan ($32)
This currently puts me at $535 / $455 after rebate, missing my motherboard, power supply, storage, cooling, and DVD drive. I don't know what to do with the harddrives yet.. how important is having SATA 3.0 for my drive that has Windows on it? I could grab a 500GB Seagate for $80 on Newegg and use my 160GB for Wndows, but I'm thinking about just getting 2x250 for a bit more if it's going to be a significant difference with the SATA 1.5. I'm also pretty unsure of what brands/models to get regarded HDDs, motherboards, and PSUs. I would preferably like a board with Crossfire so that I can upgrade with another card later if I need.
I'm not sure of the exact amount I have to spend, so I may be able to go a bit over $700. Is this even possible with these 3 items or am I going to have to drop a bit in quality?
(EDIT: Added CPU Fan)
