Tom's Hardware Forums » Homebuilt Systems » New System Build » need compatability check on new system
Word :   Username :
Bottom
Author
 Thread : need compatability check on new system
Profile: member
More Information
I'm planning on building a new machine for gaming. I'd like it to be able to run crysis well and Oblivion flawlessly. Ive got $1450 to spend, it's not possible to go higher, and that must cover shipping and taxes.
What ive come up with so far...
Amd 64 X2 5000+ Brisbane (2.6GHz)- $87
Jetway 780G ATX AMD Mobo $100
Corsair (2 X 2Gb) 240 pin 800 DDR2 $87
Seagate Barracuda 250Gb 7200 rpm 3Gb/s SATA $55
Pioneer 20X DVD+-R DVD Burner $33
2 X Ati Radeon 4850 Pci ex 2.0X16 2X $170
Aerocool Masstige Silver SECC .8mm Atx Case $100
Rosewill 750W PCU $105
Total: $905
This leaves me with (just guessing) around 100-200 dollars to play with.(I'm factoring in taxes and possible shipping costs)
Notes:
  • I dont have much need for hardrive space, just speed.
  • Im free to change the power supply, mobo, dvd burner, and/or the case since i dont know much about them, but i would prefer not to spend too much more.
  • I have considered a beefier Processor, but Ive heard you dont need too much for even a game like Crysis.(considering my 2.2Ghz single core doesn't even bottleneck my system in that game)
  • To all Ati/Nvidia fanboys out there, i picked the 4850 based on how well people said it performed and it's low price compared to other good cards. But im still open to suggestions there.
  • But mostly, I'm looking for suggestions as to whether these parts are compatible, ex. whether the vid cards fit on the mobo well which fits in the case well. And also how well this might handle a game like Crysis?
Related Product
Profile: journeyman
More Information
il be the first to say, rosewill sucks.
Profile: nimble knuckle
More Information
Certainly not the way i'd do it. All looks compatible. Best of luck.
More Information
I would change the psu.
Profile: member
More Information
what's a better PCU brand that i should use?
Profile: journeyman
More Information
corsair
here
http://www.newegg.com/Product/Prod [...] 6817139006
sure its 20$ more upfront than your current one, but when you factor in rebates, its only 4$ more.
Profile: member
More Information
Thanks for the link, it sounds like a better buy too just based on the reviews.
Anyone got any opinions on the mobo? I have a basic idea of what i need, 4 240 pin ram slots, 64 X2 compatability, a standard pci slot for my network card, 2 pci ex 2.0X16 slots, and some 3Gb/s SATA plug things. But im having some difficulties finding a board thats seen as really reliable/easy to set up. All the boards ive seen always have a sizeable group who get stuck with bad service and bad boards. plus, what's the real performance difference from a board that can crossfire at X16 than one at X8?
Profile: addict
More Information
you cant crossfire with 780g change your motherboard if you want crossfire
instead go with corsair power supply almost same price
Profile: member
More Information
newegg said the 780g could crossfire, just not as good as some boards might. would the 790fx series be a better option despite the higher price? What other options are there?
Profile: member
More Information
i found this mobo on newegg.
http://www.newegg.com/Product/Prod [...] 6813131291
its a 790fx and seems pretty solid, has all the stuff i was looking for and seems to handle 2 vid cards just fine.(considering it has 4 slots for them).
But i still dont know if this is the way to go, is there another option in the same price range?
I also found the processor prices have changed, i can get a 5400+ at the same price as the 5000+ was yesterday.
Profile: journeyman
More Information
here, this is another setup which is ALOT better.
Intel Core 2 Duo E8400 Wolfdale
$189.99
http://www.newegg.com/Product/Prod [...] 6819115037
ASUS P5Q Pro LGA 775 Intel P45
$149.99
http://www.newegg.com/Product/Prod [...] 6813131299
ASUS EAH4850/HTDI/512M Radeon HD 4850
$164
http://www.newegg.com/Product/Prod [...] 6814121253
Corsair 750 watt $109
this is 888$ and rapes your current amd build.
you can adjust it howecver you like, but im just showing you the light
Profile: member
More Information
that build would cost 1052 when you factor in the other vid card, and i forgot b4 that i need a cheap copy of vista, home basic, for $90. The only reason i want it is for DX10, i dont care about it's features.
But thanks for the idea, ill consider it. Prob with the mobo is that it doesnt have X16 X16 crossfire, i dont know much about this but ive heard theres a decent difference from X8 to X16. The mobo i found with the link below is more expensive, but it has X16 for dual crossfire, and has the ability to handle up to 4 vid cards in crossfire if i ever feel like bumping it up some more.
My prob with the processor is i can still get a 64 X2 5600+ (2.9Ghz) about 87 dollars less. Plus doing a little research, and i realize this site is probably biased, CNET compared the two companies dual core cards and AMD won, and was still cheaper. http://reviews.cnet.com/4520-10442 [...] l?tag=lnav
I realize this was an old test but it certainly doesnt say the AMD dual cores are bad.
Google Ads
News
United's Computer Check-in System Fails To Leap On Leap Day
Published on March 03, 2008
Leap day (February 29) happens once every four years, but it seems that there cannot be a single leap day without mainstream media reporting about computer-related problems associated with the date. This time around, so called "Easy Check-in" kiosks at the Los Angeles International Airport (LAX) were crashing as the software did not allow passengers to check-in for the flight. Read more
Sony ships sneaky DRM software
Published on November 02, 2005
Mark Russinovich couldn't understand how the rootkit had sneaked onto his system. An expert on the internals of the Windows operating system, he was careful when it came to computer security and generally had a pretty good idea of what was running on his PC at any given time. Read more
A thin client computer for $140
Published on February 13, 2007
If a thin client system is all you need in a corporate environment, then here's a new low-cost alternative. Devon IT announced a thin client terminal with prices starting at $140. Read more
Computer tech accidentally wipes out Alaska oil fund data
Published on March 22, 2007
Alaska is calling a routine maintenance check gone wrong "the worst-case scenario", after a technician accidentally wiped out a series of crucial government data. Two sets of back-up data were also corrupted, and Microsoft consultants were unable to retrieve the data. Read more
Latest Reviews & Articles
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
SLI & Centrino 2: Gaming Laptops Battle
Published on September 24, 2008
Take four gaming laptops. Arm two of them with SLI and make the others Centrino 2-compatible. You're looking at a high-end collection of the latest mobile technology battling it out for benchmark supremacy and your hard-earned dollars. Read more
