Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Need Help Severely with CPU FAN, Case Fans and Controllers!!
Forum Overclocking : Cooler and Heatsinks - Need Help Severely with CPU FAN, Case Fans and Controllers!!
Quick System specs:
Case: Cooler Master HAF 932
PSU: Corsair TX850w
MOBO: Gigabyte GA-EX58-UD5
CPU: Intel Core i7 920
HS: Prolimatech Megahalem
VC: EVGA GTX275 FTW
RAM: OCZ Platinum DDR3 6GB PC3 1600
HDD: 3x WD Caviar Black (32mb Cache) - RAID 0
OD: Samsung LightScribe DVD-RW
Main question -- I am trying to use the Delta 120mm x 25mm PWM fan for the Megahalem, but have doubts on the motherboard providing enough power - so I need to know where I can find some 4-pin PWM splitter -to-> 4-pin molem w/ PWM cable or 3-pin fan w/ PWM cable so I can connect the fan to either the motherboard and PSU or a Fan Controller.
The PWM fan is the Delta AFB1212SH-PWM
http://www.performance-pcs.com/cat [...] s_id=24586
Fan controller I plan on getting for other case fans is the Lamptron FC-3
http://www.performance-pcs.com/cat [...] s_id=25540
or
Sunbeam Rheobus EXTREME
http://www.performance-pcs.com/cat [...] s_id=23039
Or if anyone recommends anything else???
I need a Fan Controller because I am replacing all the fans with these...
4x Cooler Master 120mm R4 series fans (Red L.E.D's) for the side pannel <- these would either be daisy chained to PSU with molex or connected to 1 channel on the Controller
3x Scythe 120mm Slipstreams for the top exhaust <- these would also be connected to their own channel on the controller
1x Delta 120mm 190+ CFM or 220+ CFM rear exhaust fan <- this would be on it's own channel (they take a lot of power)
1x Scythe Kaze Maru 140mm bottom intake fan <- this one may be hooked up to the controller or just ran to the PSU to 4-pin molex
1x Cooler Master 230mm L.E.D front intake fan <- this would be connected to either 4-pin molex or straight to motherboard (if power is enough)
So, I think I could keep everything as planned if I could find some splitter or adapter(changer) for the CPU fan to allow the power to be drawn from the PSU/Controller and have the PWM wire connect to motherboard.
Thanks for the help!
Sponsored Links
There are 1202 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
