Im having a problem with my new computer. Its a:
Intel Core 2 Quad 2,83Ghz
2x Sapphire ATI Radeon HD4870 Crossfire
8GB DDR2 Ram
ASUS P5E Deluxe Motherboard
500GB Samsung 7200RPM Harddisc
DirectX 10
- None of the parts overclocked
But still i only get 5888 in 3DMark Vantage and 43345 in 3DMark 03. When i compare to similar systems on the internet they all get at least twice that. I have checked that both windows and the ATI CATALYST software finds all of the hardware correctly, and installed the latest drivers from ATI's homepage.
I don't think the results match the power of the system? - and i cant find anything wrong, any suggests?
With your setup I would think that you can pull 16-17K in 3Dmark06 easy. I saw scores in the 18Ks for xfire but I don't remember what their CPU clock was. You have to pay attention to people's CPU clocks when comparing 3D mark scores because small overclocks will make a huge impact. If you bump your CPU up to 3.2GHz you should see some good scores.
I did a CPU OC test with 3DM06 just to get a feel for how the small bumps in the clock affects the score. Take a look. I am using a quad core like yours so you should see higher scores than this with xfire...but my 4870 is OCd to 790/1000 in these tests.
