New build sub 1k need help!
Hello,
I'm most likely going to be building a new computer in the next few days, and need some suggestions! I want it to be a gaming machine, but I probably won't be doing too much overclocking, as this will double as our family computer as well. I'm shooting for spending less than 1000. Here's what I'm thinking:
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
(seems like a good case, and there's a rebate on it now - I was also considering the Antec Sonata III with the power supply that comes with the case)
Antec TPQ-850 850W ATX12V / EPS12V Power Supply 100 - 240 V UL, CUL, FCC, TUV, CE, C-tick, CCC, CB - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371009
(This was a combo deal with the above case, and it looks like a good power supply)
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
(choosing between this one and the q6600 - a lot of people seem to think that the e8400 is better for gaming, at least in the short term)
GIGABYTE GA-EP45-DS3L LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128345
(this is the part I'm least certain about - I've heard Gigabyte boards are good, but any other suggestions are welcome!)
GIGABYTE GV-R485-512H-B Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125224
(I may crossfire this card some day, but not yet)
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X4096-6400C5 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
(cheap ram but it looks like it does the job)
LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-06 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106072
(I just need any old dvd burner here)
Some version of Vista for ~$100
Also, I may be pairing this with a 24" widescreen monitor (which I know will push me over the budget, but I'm not counting the monitor :) ) and am wondering if the 4850 will be enough to run a monitor of that size in a decent resolution?
Thanks a TON for any input you can provide - this site is great!
8 answers Last reply
More about build help
  1. If you are planning to crossfire, I would go with an x38 or x48 mobo.
  2. very good
  3. Great, I'll take a look at those x38 and x48 boards. One I found is this one (but it might be a little more than I want to pay):
    GIGABYTE GA-X48-DS4 LGA 775 Intel X48 ATX Intel Motherboard - Retail
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128336
    Do the x38 boards do PCI Express 1.0 and the x48 do PCI Express 2.0? Does that make much of a difference yet?
  4. no the x38 and x48 both have pcie 2.0 x16
    most of hte x48's have some fancy features like more usb connectors and sata hookups
    this seems to be a very reliable board with great features and CF available
  5. Like Shadowthor said your motherboard choice (which is a very good one) doesn't do crossfire. It's a great single card motherboard though. If you aren't going to do crossfire then that power supply is way overkill. the Antec Sonata with the 500w Antec Earthwatt that you mentioned in your post would be a better choice.
    The X38 and X48 are the best choice by far for crossfire, all the X38 and X48 have the PCIex16 2.0 If you go with the X38 or X48 then the 850w and the antec 900 would be fine......heavy in the PSU department, but fine.
  6. Yeah, I was thinking about going a little lighter on the PSU, and maybe even choosing the Sonata III - I was a little worried about airflow with the sonata vs. the 900, but I'm sure both of them would be fine in my case.
  7. I suppose I could get the Sonata III and use its power supply, but still get the x48. Then if I ever wanted to crossfire, I could always upgrade the PSU at that time. Does anyone know if the Sonata III is large enough and has enough airflow to handle two video cards like the 4850?
  8. OK, I'm also looking at this PSU to pair with the Antec 900:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
    It's a 550W PSU - I'm sure that can handle 1 4850, but will it be enough if I ever decide to crossfire?
New Build Systems Product
