help with build
Word :   Username :
Bottom
Author
 Thread : help with build
Profile: stranger
More Information
here are the pieces i will probably go with.....
antec 900 case
seagate 250gb sata hd for housing games
dual seagate 750gb hd for music, movies and pics
evga geforce 8800 gt card
crucial ballistix (2x1gb) x2 memory
intel core 2 duo e8400 3.0ghz processor
silverstone fan controller
ocz memory cooler for ddr1/2
artic cooling freezer 7 pro 92mm fan for cpu
artic cooling accelero vga cooler
now i am just in need of some advice for a power supply and a mobo.... i intend to run my build in raid1
if anyone has any advice on a ps and mobo that would be great.....i would also appreciate any comments on my current build so far........thank you for all of your time and hope to see some great feedback......thanks a lot
pancakes
Related Product
Some call me ... Tim?
Profile: enthusiast
More Information
A good P45 board will do just nicely, and if you're going to stick with one graphics card, the Corsair 550VX ought to do just fine. Ignore anyone telling you that you need an 850W PSU to power that... it's just bogus.
It's probably better to run 2x2GB sticks instead of 4x1GB sticks.
Will you be overclocking?
It looks like you'll be doing some gaming, so you might as well step up to the HD 4850 instead of the 8800GT. I think that you'd have to change your VGA cooler in that case, but it should significantly out-perform the 8800GT for not too much more, particularly after rebates!
Profile: nimble knuckle
More Information
I'd go with the new ATI HD4850 for a graphic card. About $160-$170 after rebate and benchmarks considerably higher than the GT8800.
Either a P35 motherboard
http://www.newegg.com/Product/Prod [...] 6813128086
or a newer P45 motherboard
http://www.newegg.com/Product/Prod [...] 6813128344
no crossfire, but raid.
PSU any quality 450w-550w
Antec Earthwatts $55
http://www.newegg.com/Product/Prod [...] 6817371007
or a corsair 450w or 550w
If you decide you want crossfire, then all this would be different.
More Information
Zipzop nailed it first, good catch on the 2x2 RAM
Message edited by dirtmountain on 07-08-2008 at 06:34:12 AM
Profile: stranger
More Information
i will probably not be overclocking, at least for now since i have no real knowledge to do so and i would would prob fry some parts
i am considering going dual 8800gt cards or at least sometime in the future(are the hd4850's really that much better? seems like from what ive read there isnt much of a difference)
thx for the ram suggestion, i will have to shop around for that
i am really not that savvy when it comes to computers, so all help is appreciated, i believe i can find a decent power supply on my own, i guess i am just looking for some more detailed info on a mobo, and yes i will be mainly using this rig for gaming
thanks again for everyones time
If the women don't find you handsome, they should
Profile: journeyman
More Information
Hey pancakes
The 4850's are significantly better, and not much more money. If you ever hope to go with a dual video card setup in the future the Crossfire platform is as good as any, particularly with the new 4850 and 4870 cards. Which can also be mixed up by the way. Buy a 4850 now, and if you want you can add a 4870 later!
Going with the possibility of Crossfire though means you'll have to go with a motherboard with an Intel Chipset. P35, X38, P45 and X48 are the most common, and all are good. X38 and X48 are the performers and will allow the dual video cards to really stretch their legs, while the P35 and the P45 chipset motherboards will restrict the bandwith available to the cards to a degree. Tests have shown this can make a substantial difference in framerates depending on the game played and the resolution being used, particularly with these newer more powerful cards in Crossfire. Also the X38 and X48 chipsets are known to be very good overclockers.
I know...I know someone in another forum told me that the MSI MoBo with a P45 Chipset had recently broken records. But hey, unless you plan on doing voltmods on the board and using liquid nitrogen for the CPU and to cool your volt modded video cards......well, that's just nuts!!!
And if you are thinking of Crossfire or sli for that matter, down the road, get a decent name brand power supply. I know they aint glamorous, but if you have a system that's using 400 watts, and your PSU is rated for 750 (which I'd use....oh wait, that's what I do use :-)). It will run more efficiently, run cooler, and most important it will have more accurate voltage regulation and also be much less likely to fail, and possibly taking critical components with it:-)
Anyhow,,,,didn't meant to bore you to tears, just had to get my two cents in.
Good luck with that build!
The Canuck
Google Ads
News
Microsoft ships first post-beta 2 build of Vista
Published on June 27, 2006
Late Friday, Microsoft shipped Windows Vista build 5456, its first post-Beta 2 version of the next major Windows release. Read more
Microsoft Releases New Build of Windows Vista
Published on September 25, 2006
Microsoft has released an interim build of Windows Vista to its usual testers as well as to some 100,000 of the participants in its Customer Preview Program. Read more
PhD Student Makes World's "Most Advanced" Walking Robot
Published on May 23, 2008
Delft (Netherlands) - A PhD student at the Delft University of Technology in the Netherlands has constructed what he says is the world's most advanced walking biped robot. Read more
Vendors form collaborative to push AJAX
Published on February 01, 2006
The market for AJAX (Asynchronous JavaScript and XML), a technique for developing interactive Web applications, is heating up with the announcement today that several vendors, including IBM, BEA, Borland, Novell, Oracle and Red Hat, have formed a collaborative to help push AJAX in the open-source community. Read more
Latest Reviews & Articles
Best Video Cards For The Money: Oct '08
Published on October 06, 2008
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
