Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Does Arctic Cooling Freezer 64 Pro fit socket AM3?
Forum Overclocking : Cooler and Heatsinks - Does Arctic Cooling Freezer 64 Pro fit socket AM3?
I was just wondering if Arctic Cooling Freezer 64 Pro fits Socket AM3 Boards (I have seen my phenomII go past 62 degrees after an hour of prime95)
Setup:-
CPU:AMD PhenomII 955 BE @3.2 GHz (On a stock ccoler)
Motherboard:Gigabyte GA-MA790XT-UD4P
GPU:Sapphire Radeon HD4870 512 MB (exhausts hot air out of the case)
PSU:Gigabyte ODIN Pro 550W
Ram:2x2GB Kingston KVR 1333 DDR3
HDD:WD 500GB & WD 160GB
Case:Gigabyte Setto 1000
Sponsored Links
Yes it does fit. I have the same mobo as you and 720 BE and the cooler fits.
Reply to juncwil
Thanks very much,I just wanted to know for sure. But does anyone know if it fits in A gigabyte setto 1000 case?
Message edited by youssef 2010 on 07-16-2009 at 10:17:34 PM
Reply to youssef 2010
It will fit in there, the cooler is not really that big.
Reply to juncwil
Thanks again,I am only asking so much questions because I live in Egypt & I have only one shot at this,so I have to be absolutely sure every thing will fit.
As far as fitting the cooler and making sure the side panel closes, yes... The only issue that you may encounter is the fan might lean over the first 2 ram slots but it should not be a problem.
All AM2+ coolers are compatible with all AM3 motherboards
------------------------------ http://i683.photobucket.com/albums/vv199/OvrClkr/Valid.png
http://i683.photobucket.com/albums/vv199/OvrClkr/FLASH.gif
http://i683.photobucket.com/albums/vv199/OvrClkr/432ghz.png
Reply to OvrClkr
There are 1283 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
