Radeon HD4850, Crysis, Vista problems
I've recently just put together a system for a friend, and before i do any updates, i wanted to test out crysis' performance on it. Its an Intel E8400, Sapphire HD4850, 4GB RAM, Vista 32Bit.
Upon installing it said there was a necessary system update which needed to be done, but i ignored it and carried on, wanting to test performance on a plain machine before contaminating it with fista updates.
whilst playing crysis, i had all settings on high, and 4x AA for giggles, but during the drop sequence from the aircraft, i got down to chute height and the game dropped back into windows after freezing.
Does anyone know of a fix for this problem, or is it just that i was too lazy to wait for all of the updates to apply?
Thanks
2 answers Last reply
More about radeon hd4850 crysis vista problems
  1. you need to give us more info about the system. which driver's are you using?
  2. the 8.5 catalyst one which came on the CD.
    motherboard is Gigabyte GA-P35-S3G
    Thanks
    DC
Homebuilt Crysis Windows Vista Systems
