Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Quad 750 power supply & Cooler Master Stacker 830
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Quad 750 power supply & Cooler Master Stacker 830
Any idea if this power supply will fit in this case? I tried putting it in my old Thermalright Armor case and it wouldn't fit. There was a bottom metal part that was blocking it and the power supply was too wide for the case =\. Heres the case i'm thinking of getting:
Case: http://www.newegg.com/Product/Prod [...] 6811119103
My power supply: http://www.newegg.com/Product/Prod [...] 6817703009
Sponsored Links
Nice powersupply I've got the 860 (850??) Watt model in my server.
Hows abouty:
http://www.newegg.com/Product/Prod [...] 6811112140
that will definitely take your PSU (as it takes E-ATX motherboards = server case).
Lian-Li forever!! :sol:
Bob
Reply to bobwya
Eh, i'm really liking the coolermaster cases atm and thats what i'm thinking about trying next.
In the reviews they said it fits the coolermaster cosmos S, I just want to be certain with that as well, i'd get either one
http://www.newegg.com/Product/Prod [...] 6811119150
Reply to Anonymous
can you tell me how wide the psu is? the dimensions? ill do you a favor and measure my psu and you'll figure it out from there
i have a cm stacker 830, make sure you send me a message cause ill prolyl forget to check this message
Message edited by eklipz330 on 08-30-2008 at 05:22:35 AM
Reply to eklipz330
Ok sent you a PM
Message edited by Anonymous on 08-31-2008 at 12:49:19 AM
Reply to Anonymous
hmm, i have the armour and the 750 and although a slight squeeze, it does fit.
however, i have just hacked my way through building a new comp with the antec 1200 and it has tons of room due to the placement of the psu at the bottom. bit of a stretch with the cpu power cable though.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
There are 1268 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
