Looking for a little help, as I'm stumped. I've noticed my P4 530 (Prescott) has been running at 2009 MHz, rather than the 3015 MHz at which it should run (this has been checked using Everest, CPU-Z, and other diagnostic tools under OS X). I've updated the bios, reinstalled the chipset drivers, reset the bios, switched to the backup bios, and so forth. Nothing I do seems to have any impact on the CPU speed.
I've booted into OS X (10.4) and the "About this computer" dialog also lists the speed as 2GHz.
Just moments ago I took the machine apart and put it back together - everything is seated correctly and has been dusted. Having changed nothing in the bios between when it was running at 2009 MHz and now, the clock speed has dropped again - it's now running at 1.51 MHz.
CPU-Z tells me the FSB speed is only 400MHz and the multiplier 100. I've attempted to "overclock" the machine using the godawful Gigabyte tweaker, which simply resulted in hard crashes each time.
The bios MIT system doesn't let me specify anything but an arbitrary speed setting (CIA2 - cruise, turbo, full thrust, etc) and the CPU host controller rate - these settings have no impact on clock rates as far as I've seen.
SpeedStep isn't supported on this CPU, and the power management setting in XP is set to "always on".
I've searched and searched for a similar situation, but the solution for every similar problem I've seen has been "turn off SpeedStep" or somesuch.
Do you know how hot your CPU runs? It might not support speedstep, but P4 support thermal throttling.
------------------------------The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. - Rebec of Ginaz
Reply to Zenthar
Almost sounded like "hard to say what in blazes is causing it".
Edit:
I agree with Zenthar, it could be overheating and throttling down, since the OP mentions it dropped even further. Its been soo long since I've ever seen my P4 northy throttle. . o O (thing is.. it never did)
Message edited by Grimmy on 08-30-2008 at 03:34:34 PM
^heh... in XP there isn't an off for power options which would be power management. But the OP is runing OS X. . o O (which is stating the same thing)
Edit:
And if it is over heating (since he mentioned he cleaned it up).. it should only be a matter of time when the system shuts off, that is if the thermal trip still works.
OP - Did you take the HSF off to clean it, and re-apply the thermal grease correctly?
Message edited by Grimmy on 08-30-2008 at 04:10:14 PM
Ah damn, looks like I pasted the first version of the post I wrote rather than the revised version. Ah well.
It's a GA-8i915P Duo Pro.
The CPU isn't overheating - it's runs consistently at around 35-40C (100F or thereabouts). I've cleaned the die and heatsink and reapplied thermal paste (was one of the first things I did).
It runs XP most of the time, OS X occasionally, but that does rule out any system-level cause.
And yeah, typo on the multiplier thing. My brain is only half functional at the moment, as I just cannot figure out what would be causing this.
It may all be rather moot though - as of this morning, the machine simply won't boot up. It gets power, but nothing happens.
I'm just about ready to throw in the towel at this point.
I wounder if his mobo is setting the multi lower than it should be. Although since he probably does not have Speedstep then his multi should always be locked at the max which is 15.
I did hear about certain mobos that may bot support the multis but that was with Intels new half multis (i.e. 9.5x).
Something is wrong if its not allowing it to stay at 15x.
Unfortunately not, as I can't get into Windows. I can tell you the same details but they won't be verfied.
For the last day I haven't even been able to boot the machine - components get power, and nothing happened.
Without changing anything at all, I tried it again today, and the machine booted at 100x15, but wouldn't find any boot devices.
A few attempts later, it booted at 133x15 (Windows bluescreens, OS X panics) - then stopped booting again.
I reassembled the machine *again* and managed to get the machine to boot from a MemTest disc at 200x15 (first time I've seen that since I noticed the initial problem).
Anyway, the machine is running tests now but I don't think it's anything that MemTest would find - just covering all bases for good measure.
Seems pretty fubar to me, but I'll run some more diagnostics with UBCD and see how it fares.
Message edited by grammaticus on 09-01-2008 at 04:14:27 PM
...and after rebooting from Memtest to UBCD, it's at 133x15. Bizzare. Can a P4 be throttled back if insufficient power is available? I seem to remember the core voltage hovering around 1.3v and then some when the system was running at 2GHz, which is about right as far as I know.
