Alright so I have a motherboard in my computer which has 2 memory slots and theoretically/technically supports 2gb of R.A.M, I was wonder would it be possible by any chance that it would support 3gb of R.A.M???????? Replys and advice would really be appreiciated on this. If you need to know my motherboards basic specs and stuff, just say so and I will post a reply with the specs for you. Thank You.
No if it supports three GB of ram then it would support 4GB. If the specs say 2 GB then it's just 1GB per slot. I could always be wrong, but the odds are against it.
And if integrated graphics chip affects this, I dont use it, i have another real videocard working and if power supply affects the amount of ram supported by any chance then it came with I think a 300watt psu but I replaced it with a 500watt psu.
