Alright, this is a 2 part question so bare with me
First, i'm wanting to sell my old rig but I don't know what to ask for it. Most of it is over 2 years old. It used to be overclocked, I got the cpu up to 2.4ghz and the ram up to 433 but then the cmos battery died and lost bios settings. here are the pieces with links to newegg
AMD Athlon +3600 2.0ghz dual core socket 939 (yes i know, last of its kind, cant find link)
zalman 9500 HSF
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223
Asrock mobo (apg/pci-e slots) 4xddr400 slots 3 pci slots 939 socket
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157081
4x512 OCZ ddr400 ram (2-3-3-6 timings i think)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227031
nvidia 7900 gs 256mb ram 256mb mem interface 500mhz core clock
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130056
sony dvd burner (does everything but hd dvd and bluray)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827152076
So could someone give me a ballpark range for a pricetag? Thanks
Also, buying a new system and I would like some advice on the parts im buying, or recommended parts because im not too sure on these yet.
Gigabyte mobo am2+ socket 4xddr2
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128081
Diamond radeon hd 3870
http://www.newegg.com/Product/Product.aspx?Item=N82E16814103050
gskill 2x1gb ddr2 800
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
Any recommendations for other parts/brands that i would be better off with?
Thanks for the help
zalman 9500 HSF
Thanks for the help
