Tom's Hardware > Forum > Motherboards & Memory > Memory > Wich one is dead or causing problems?
Forum Motherboards & Memory : Memory - Wich one is dead or causing problems?
Poll with 10 possible answers.
Warning, if you click on "see results", you won't be able to vote
I have some big problems with my system.It wont boot anymore.I tried to overclock my E8400 to 3.8 ghz and when I rebooted there was a message showing up saying NEW CPU DETECTED but I didn't change my CPU.I changed the voltage to 1.2 and fsb to 1689.Every time I push the power button all the fans turn on and that's it. No bip ,no post, the monitor is acting like it doesn't receive any signal.NEED OPINIONS .
Sponsored Links
Remove the battery for 30 seconds and try again.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Reset your BIOS and it will work again...
Reply to aziraphale
I removed the battery for more than 2 hours and the reset cmos pin too.
Reply to yetyhunter
Can you list your motherboard and psu? 1689mhz is a high fsb, too high for some of the old chipset motherboards. Psu is possible, although less likely. 3.8ghz for e8400 should not be a problem. E8400, even if it's e0 or m0 stepping instead of c0, should oc reliably to 4.0ghz.
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
^+1
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
I have an ASUS P5N-D with the nvidia 750i Chipset.And a 600 W PSU it works fine had no problems with it.
Reply to yetyhunter
I'll assume you reset the CMOS correctly. You can either remove the battery, or use the jumper.
Did you discharge your static before you went jangling around inside the computer?
All the fans turn on. What about LEDs? Does your HDD spin up?
Check to make sure you didn't unseat any power connectors. Also, check to make sure you didn't create a short on your mobo somewhere (remove from case if you have to). Did you remove your CPU at any point? RAM? You may have reseated them incorrectly.
Did you apply any higher voltage than 1.2v?
If I had to bet the farm, given what you've said, I'd bet mobo.
Reply to seboj
I had the same problem with a P5n-D and ended up RMAing it. It was working one night, then the next morning it just died, wouldn't boot at all. No other component was broken (I know because all of them are currently in use with a new mobo) and I had no overclock.
Still don't know what caused it but my new system is up and running so I'm happy.
Reply to OrderChaos
The motherboard led was on and the HDD was working.I only changed to voltage to exactly 1.2000 and the fsb to 1689 ,the ram was linked in sync mode at 869MHZ default 800.I removed the battery and used the jumper.
I didn't touch anyting inside the case just changed settings in the bios.
I sent my mobo back to the shop but they need to check if the mobo is the real problem before replacing.If it's not the mobo I need to pay 50$ for service.what do you think ?I shure hope it's the mobo.
I had exactly the same problem with a older mobo. All fans turn on but no post no bit, nothing.That happend when my PSU exploded and fried only the mobo.
Reply to yetyhunter
Need opinions It's between the mobo and the cpu wich one is it????
And why can't I see the results??
Reply to yetyhunter
Can you please list the specific model of the PSU?
There are 1314 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
