New system E8400 running at 92 Celsius and shuts down when istalling V
Last response: in CPUs
Hi
I've built a new system for myself and for some reason it shuts down when I try to install Vista. I noticed that in the bios settings that the CPU is running at 92 Celsius, maybe that's causing the problem?
I tried re-seat the heatsink but that didn't work, it's still running at 92 Celsius although I didn't try installing Vista after that. Does bios tell the true CPU temperature?
Will I have to buy a new heatsink? But why isn't the original one working?
Thanks
Thanks
More about : system e8400 running celsius shuts istalling
Related ressources
- E8400 at 117 celsius ? - Forum
- PC shuts down when it gets below 40 Celsius (i guess 104 F) - Forum
- Computer Shuts Down When The GPU Temperature Goes Over 95'C, Will A Ne - Forum
- New System shuts down at OS Install - Forum
- AMD FX-8350 45Degrees celsius Idle temps, high? - Forum
Here another one but it's big so link below:
http://img257.imageshack.us/img257/6572/image032ah0.jpg
kashifb said:
Here another one but it's big so link below:http://img257.imageshack.us/img257/6572/image032ah0.jpg
That doesn't tell much either. Push down on it. Is it loose? Lga775 pushpins can be pretty flimsy. You can also try disabling fan control in bios, so that the fan spins at 100% all the time.
kashifb said:
What exactly do you want to see in the picture?The heatsink is down as much as it can go.
The fan speed is around 2000 mostly below it if that's helpful.
Maybe it's stuck censor then, although 92C would be an extreme case of it. If it's stuck, and the cpu is actually cool, it'll throttle and shut down anyway. Can you feel the heat from it? Press you finger on it and feel the burn and whatnot...
kashifb said:
How ca I disable fan control in the bios?It's different for every motherboard. Look through the bios options. It should be something straight forward, like "cpu fan control method" or something like that. Just set it to disable.
kashifb said:
If it is a sensor, what's the solution?You can't fix stuck sensor. Have to rma it.
I can tell you for 100% certanty, from that picure your cooler isn't mounted on right.
You need to pull it off.
Turn all of the pins in the lock position opposite way of the arrow, "clockwise" I believe. I can see two of your pins in the unlock position.
Pull your motherboard out.
Go to radioshack, and buy some new thermal paste cause now you have contaminated it to bad. You will probably skip this and wonder why your temps are still bad, but then comeback and read again.
Redo the thermal paste, A BB size amount in the middle of the CPU, make sure the old paste is cleaned with Rubbing alcohol.
Put the CPU in the mobo, lock it in, and with the mobo out of the case push the pins down like this. Make sue they are all clockwise locked!
Go in a X pattern.
top left
bottom right
top right
bottom left.
Now your CPU is installed right and has non contaminated thermal paste.
Have fun with your new rigs at good temps.
Go in a X pattern.
top left
bottom right
top right
bottom left.
dagger said:
So it is mounting after all. I say forget about the crap pushpins and pay $30 for a real heatsink with backplate.
Push pins work perfect. You have to know how to put them on. When done properly they work just like they are supposed to. When you got a pin in the open slot you can hit it with a hammer and it wont lock in.
The other flaw is from people when the mount the mobo in the case and the try to push the oins in and the mobo flexes and the pin botoms out on the mobo tray not allowing it to go in.
If you pins are all in the lock position and you lock em in the mobo out of the case its so easy a baby could do it.
the same kind of situation happened with me
i have reduced the memory frequency in the bios and everything went fine
go into bios and fix a lower frequency for ram
and keep the settings for ram timings as automatic
try different ram speeds
if not then try removing the cmos battery for a minute and then keep it and set the memory speeds again
forget about temperatures and try to install vista every time
this may be time consuming but may become good for you
roadrunner197069 said:
Clockwise is locked counter clock wise is not. You want them all clockwise.AKA opposite the arrow direction. The arrow direction is for taking it off.
The screwdriver slots will point out in a x when all are in lock position.
Sorry but I still don't understand!!!
If I turn the pin clockwise or anti-clockwise, it just keeps on turning. Which position do I stop it in to open it?
venkat karthik said:
the same kind of situation happened with mei have reduced the memory frequency in the bios and everything went fine
I'll try that as well, thanks.
A BB like in BB gun. Similar to about 2 grains of rice.
Like I said if your pins turn around infinite, they are broke and it will never work.
If all work except one you still wont get good contact and will overheat.
If you dont mind heating your CPU to 90C and taking precious months off of its life everytime. Go ahead and keep trying to fix the problem with tape and gum.
I'm done.
You can lead a horse to water but you cant make him drink.
I'm done.
Related ressources:
- ForumComputer shuts down during game play
- ForumIs my E8400 overheating?
- ForumCPU RUNNING OVER 100 degrees CELSIUS HELP
- ForumTemps Question for overclocked E8400
- ForumPC Randomly shut down in games.
- ForumPC SHUTS DOWN BY ITSELF
- Forumnew prescott sends northbridge to 100 degrees celsius !!!!
- Forum[HELP] HIS ATI 7750 shuts down Screen LCD & Freezes PC
- ForumNew e8400 Build is up and running
- ForumPOST problem with P45 / E8400 new build
- ForumE8400 FAIL AFTER OVERCLOCKING
- ForumSystem shuts down under 100% CPU load.
- ForumPSU Help
- Forumcomputer doesn't power down
- Forumneed help overclocking my E8400
- More resources
