hi guys,
i am about to upgrade my system and was wondering what power supply should be enough to power that beast of a card.
its an overclocked version and i will be mainly using it for playing games.
here are the rest of the specifications,
BFG 680i Sli mobo
BFG 8800 Ultra VGA OC
2GB Corsair cas5 xms2
500 GB Seagate 32MB
Q6600 Go stepping (finally made up my mind to go with quad core)
Audigy 2 sound card (still gonna stick with it dont think its worth getting an Xfi)
Antec three hundred casing
Pioneer DVD RW
any suggestion will be highly appreciated.
thanks
Sponsored Links
Any 500W+ will be fine.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to Strangestranger
i don't know about the ultra but the 8800gtx that i have needs two 6 pin connectors. so just to be safe and also as an investment for the future i'd say get a psu with at least 600W+ that has the 6 pin connectors required. i have the 600W ocz stealthxstream. the thing is extremely quiet and it's 120mm fan keeps it running cool and very quiet.
------------------------------ AMD Athlon 64x2 4600+ @ 2.6ghz (lapped) | MSI K9N Platinum mobo | eVGA GeForce 8800gtx | OCZ 2x2gb DDR2 800 | OCZ StealthXStream 600W psu | Creative Sound Blaster Audigy SE 7.1 | 500gb Seagate Barracuda hdd | SAMSUNG 20X DVD±R Burner | Raidmax Smilodon
Reply to ixnemesisca
avoid
koolman007 wrote :
any opinion on this model by hipper..
http://www.ebuyer.com/product/109552
Actually its Hiper but what the **** - who cares!! That model is OK... I have used it myself and it is nice and stable. But I wouldn't personally hook it up to an 8800 Ultra.
A better bet for your rig would be:
http://www.ebuyer.com/product/114941
The Corsair PSUs use better quality components. That is also a modular PSU like the one you suggested.
For future SLI 8880 Ultra (yey!!) I would get a 1KWatt Ultra X3, Thermaltake Toughpower or Corsair 1000HX:
http://www.ebuyer.com/product/143019
http://www.ebuyer.com/product/133804
http://www.performance-pcs.com/cat [...] s_id=21545
(will ship cheaply to UK)
But not sure if SLI is worth the bother though!! :sol:
Generally it is best to work from Tiers 1 & 2 from this quality guide:
http://www.xtremesystems.org/forum [...] p?t=108088
Enermax are apparently over-rated and some of the very cheap Antec PSUs are actually very good Seasonic rebrands.
Here is a calculator for your system wattage:
http://www.extreme.outervision.com/psucalculator.jsp
It never seems to gets the GPU wattage right (it may assuming full 2D load) so use:
http://en.wikipedia.org/wiki/GeForce_8_Series
for your Ultra (175 Watts full load - ouch!!)
Bob
Message edited by bobwya on 08-31-2008 at 04:25:32 PM
Reply to bobwya
if you haven't already bought the ultra, i would suggest looking into a better card.
Reply to Nik_I
wow!!
thx for the informative post Bob.
it really helped me out and i have decided to go with corsair 650W TX series :)
i reckon its not only worth the extra 20 but also makes my pc more future proof.
Nik i have already bought the VGA (very cheap) and as far i know it performs better than a 9800 GTX
http://www.digit-life.com/articles [...] part3.html
thx again guys
Reply to koolman007
+1 but surely OP wouldn't list that to purchase with the 4870 (X2) out!! Like no way... must be lying around his bedroom!!
Good choice of PSU - should be nice and stable!!
Bob
Message edited by bobwya on 08-31-2008 at 06:21:39 PM
Reply to bobwya
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Need Experts advice.....
There are 1227 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
