My system is well
Intel DG33TL
Q6600 2.4Ghz
4Gb Memory
1 DVD Driver
4X Hard Drives 7200 Rpm
2 Case Fans
8800GT 512
and I Am running just a 550 Watt from Corsair been running like this for a few months no problems
Will it be able to run 2 8800 GTS 512? I think it's good quality because it's made in germany .Germans make good stuff. Here is the official site:
http://www.xilence-power.com/
Ok thx. The PSU is not defectiv i've been using it for over 8 months now and had no problems with it . But could it run 2 8800 GTS 512 with a 31A +12v rail?
31amps on a single 12v rail is low for 2 g92 8800gts, although it may be enough. But that's cutting it close.
Requirements
Minimum of a 400 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 26 Amp Amps.)
Minimum 450 Watt for SLI mode system.
(Minimum recommended power supply with +12 Volt current rating of 30 Amp Amps.)
An available 6 pin PCI-E power connector (hard drive power dongle to PCI-E 6 pin adapter included with card)
It should be enough because I have only 1 HDD and 1 DVD drive.Not a power hungry system. What do you guys think???
It might, but be prepared to get a new psu if it turns out to not be enough. A more typical 600w psu will easily handle it. But yours is a pretty bad one with low 12v rail ampage.
