Low power
Forum CPU & Components : Other Components - Low power
What is the sign of low power for graphic card?
Sponsored Links
Crash. :p
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
- 0 +
how bout screen lagging problem..like display got those lines bla bla...? i using convertor for my 8800gts 512mb with 400watt psu...i think its my pwer not enough
Reply to enson
- 0 +
That's usually due to overheating or bad drivers. Lacking power tend to make the program crash completely.
Reply to dagger
A branded 400W PSU shouldn't have any issues. What is you PSU and specs?
Lagging and crashing would be normal symptoms of low power. Lines and artifacts usually mean overheating. Might wanna grab ATI tools: http://www.techpowerup.com/atitool/ Scan for Artifacts and watch your temps. You do not want it to go over 85C, although the 8800GTS can do up to 120C~.
If it starts overheating and artifacting, grab Rivatuner and increase the fan speed to 100% and test again. If there's still artifacts (yellow dots), try reducing your clock speeds.
Reply to halister_one
- 0 +
i put all defaults....and ntune shows my gc temperature is around 50d...consider cool rite..
Reply to enson
- 0 +
If that's full load, temperature is cool.
Reply to dagger
- -1 +
Here are a few:
http://www.mysmiley.net/imgs/smile/sign/sign0147.gif
http://www.mysmiley.net/imgs/smile/sign/sign0138.gif
http://www.mysmiley.net/imgs/smile/sign/sign0010.gif
Reply to DXRick
- 0 +
enson wrote :
i mean idle..
Then it's hot. :na:
Run prime95 (small fft) and monitor how warm it gets:
http://files.extremeoverclocking.com/file.php?f=103
Reply to dagger
dagger wrote :
Then it's hot. :na:
Are we talking about cpus or videocards? :??:
- 0 +
Lol, sorry, I was thinking of another thread. Use this instead:
http://www.ozone3d.net/benchmarks/fur/
Reply to dagger
- 0 +
graphic card dude hahaa
Reply to enson
Tom's Hardware > Forum > CPU & Components > Other Components > Low power
There are 1035 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
