Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > EP35-DS3L BSOD problem
Forum Motherboards & Memory : Gigabyte - EP35-DS3L BSOD problem
My board is BSODing on me a lot. I have all the latest drivers and Vista updates. I'm running the F5 bios. I'm not sure where to get the BSOD error message, so if you guys can tell me where to find it, I'll post it. Should I post a dxdiag log? Any help would be appreciated.
My system:
Q6600 @ 2.4Ghz
4 gigs of g. skill ram @800mhz (PC26400)
EVGA 512-P3-N802-A1 GeForce 8800GT
Western Digital Caviar SE16 WD3200AAKS
Western Digital Caviar SE WD5000AAJS
ARCTIC COOLING Freezer 7 Pro
OCZ GameXStream OCZ700GXSSLI 700W
Vista Home Premium x64
Message edited by jorder247 on 10-02-2008 at 04:32:18 AM
Sponsored Links
The first thing I'd do is test the RAM - one stick at a time, and at least overnight...
There's a GREAT Gigabyte forum over at:
http://forums.tweaktown.com/f69
You'll find a 'sticky' there on memory testing/tweaking that is very detailed, and has pointers to the s'ware tools you'll need.
Good luck
Reply to bilbat
Thanks for showing me that forum. By looking at it, I'm pretty sure it's a problem with the S3 sleep state. I've asked over there for any tweaks they could recommend to fix the problem.
My mobo is a Gigabyte EP35-DS3L running the F5 bios.
Reply to jorder247
memtest each stick for 8 passes and then together:
http://www.memtest.org/#downiso
Reply to auscanzukus
There are 1110 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
