Hello,
My HTPC turned off last night. When I went to turn it back on, nothing. I thought it was the power supply, so I unplugged the 24-pin connector to the motherboard and plugged it back in. Still no luck. So, I swapped out the power supply. Still nothing. So, I figure it's either the CPU (Intel E6750 C2D) or the motherboard (Foxconn P35A-S). Anyone else have any ideas or definite answers as to what might be the cause?
Thanks,
Dan
Message edited by marchewd on 10-02-2008 at 07:16:06 AM
Sponsored Links
I have the same issue.
My computer turned off by itself while I was afk for an hour. (no lightning or power outage happened).
Motherboard: ASUS M3A
The LED light on the motherboard is on.
When I press the power button on the computer, the fans twitch once like they are trying to start, but nothing happens.
I checked every connection.
I reseated all the hardware (CPU, memory, etc.)
I tried a different power supply and it still did exactly the same thing, so it's not the power supply.
Do you think it is a motherboard issue? Or CPU?
Thanks!
--Mike
Reply to Veknor
My issue turned out to be the power supply. It worked in a different setup, so I figured it wasn't the problem. I got a new motherboard and CPU and still had the same issue, so I replaced the power supply and everything started right up.
Dan
Reply to marchewd
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Motherboard/CPU problem
There are 1219 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
