Yes No
Ads
Tom's Hardware > Forum > Overclocking > Heatsinks & Air Cooling > Best Water Cooling System
Forum Overclocking : Heatsinks & Air Cooling Best Water Cooling System
Read up on some forums, including the ones in this topic. I have been looking into getting a water cooling system by Swiftech and I am finding that overall this one looks right. http://www.swiftnets.com/products/ [...] A-plus.asp . I just want to make sure that I am reading everything correctly before I make a finalized purchase and confirm that it is compatible and no other purchases will be necessary to make it compatible (adapters, fittings, etc..)
CPU: http://www.newegg.com/Product/Prod [...] 6819115202
Mobo: http://www.newegg.com/Product/Prod [...] 6813188046
RAM: http://www.newegg.com/Product/Prod [...] 6820145224 x2
Chassis: http://www.newegg.com/Product/Prod [...] %20whisper
HDD: http://www.newegg.com/Product/Prod [...] 6822136296 x3
GPU: http://www.newegg.com/Product/Prod [...] 6814130442 x1 right now but x2 in the future
PSU: http://www.newegg.com/Product/Prod [...] pk=HX1000W
Thanks
Reply to Mandlevi
Ugh, I had a post going and hit refresh...got rid of it all.
Need a bigger rad...esp if you are adding in that GPU to the loop. That radiator will only work (at stock speeds) on your i7. Add another radiator of equal or greater size if you want the loop to include that 280.
http://martin.skinneelabs.com/index.html
Read up on rads/cooling/watts/fans/pumps/flow rates.
Reply to rubix_1011
Read all of this too, don't rush, read a LOT!
Guides
http://forums.extremeoverclocking. [...] p?t=282232 Pretty up to date info and buying guide
http://gilgameshreviews.com/index. [...] s&catid=40:overclocking-and-cooling&Itemid=86 Another good guide
http://forums.extremeoverclocking. [...] p?t=312743 What to do once all the stuff is in the door
http://www.xtremesystems.org/forum [...] p?t=223835 Many build logs on MANY cases, great learning tool.
My latest rig:
http://www.ocforums.com/showthread.php?t=604016
Forums
http://www.xtremesystems.org/forums/index.php? Not a noob site, but great stickies
http://www.ocforums.com/ My fav, good peeps, know their stuff, less hardcore
http://www.over-clock.com/ivb/inde [...] opic=20277 A GREAT Europe site
http://www.overclock.net/water-cooling/ Decent site
Tests on equipment, not reviews, truly scientific tests
http://translate.google.com/transl [...] n&ie=UTF-8 Info on rad testing
http://www.xtremesystems.org/forum [...] p?t=220593 More rad testing
http://skinneelabs.com/ Host for Martins lab and some newer tests
http://www.skinneelabs.com/MartinsLiquidLab/ Test results, very technical
Stores
http://www.dangerden.com
http://www.petrastechshop.com/
http://www.sidewindercomputers.com/
http://www.jab-tech.com/
http://www.performance-pcs.com
Reply to Conumdrum
WOW, conundrum.
Those seem extrodinarly smilar links from the last post you made about watercooling.
Reply to overshocked
^They are the same ones. We end up answering the same questions over and over again. That's why 'read/research' is heavy on our to-do list for new WC'ers.
Reply to rubix_1011
Thanks that was the joke...Like i said the last time he posted those:
I have things already typed out for when people ask a vriety of questions about overclocking.
I read it too! The reason I asked was I wanted your direct opinions on the exact setup I had
Reply to Mandlevi
Mandelevi. If you plan to cool a i7 and the NB AND a GPU you better be looking at a MINIMUM of a 120x3 rad, possibly a 120x4 rad. That rad is just way too small. But, it is able to easily add another 120x2 rad to the loop. The pump can handle it.
So buy another 120x2 MCR220, fittings, some hose your okay.
Message edited by Conumdrum on 07-21-2009 at 05:24:34 AM
Reply to Conumdrum
Yeah, definetly need atleast a 120x3
Go to a scrapyard and check out car heater cores or motorbike radiators. Look for ones that have lots of fine channels and dense fins. Oil coolers also work okay, if you can find one small enough.
Those suckers tend to dissipate a lot of heat. They work best when coupled with impingent blocks and a high-pressure pump.
Note that you'll need a largish case - the Golf core I'm using measures at 140x200x50mm, on an i7 940 at 4.4GHz and two 4870 1GB cards. The coolant temperature (separate electronic probe, software can go stuff itself) is a constant 39ºC after it's warmed up. Speedfan claims the CPU temp is 46ºC at high, but it's known to lie.
Incidentally, don't ask what blocks I'm using, since both the VGA blocks and the CPU block are custom built.
Reply to Mugz
awesome thanks! just looking to have a set-up like this on my cosmos 1000 http://www.xtremesystems.org/forum [...] tcount=486 . What kind of pump set-up is he using on that? I looks like a DD Laing type of pump with an acrylic top and an acrylic reservoir attached to the pump.
Reply to Mandlevi
Looks like a MCP355 with a XSPC top...that would be my guess...
Reply to rubix_1011
swiftech apogee gtz cpu block : swiftech mcr320 rad : swiftech mcp355 12 vdc pump w/ xspc reservoir top: DD-GTX285 gpu block
More research, more research, more research. I love research! =D
Opinions on that WC set-up for a cosmos 1000 chassis
: The only thing I have worries about is that the 120mmx2 fan mounts located at the top of the chassis won't fit a 120mmx3 rad on it
Once again: http://www.xtremesystems.org/forum [...] tcount=486 going for that look only with my mods.
Thanks
Reply to Mandlevi
Thanks
Now that you found a really top notch forum to post at, why the heck are you still here? Be careful at XS, no stopid questions.
I'm the same name there.....................
Reply to Conumdrum
Hey... i post on XS and overclockforums and oc.net (under the same name)
But i still post here to (=
LOL me too, I'm the same name on XS and OCForums. I come here to help, I dunno why. OCF is diff than the one you frequent. It's kinda my homie place.
Reply to Conumdrum
I like overclock.net...
but ocf is alright. I just like how helpful people like nol are on overclock.net
ezkiller wrote :
damn u guys post wayyyy too long and on different forums too! holy..thats like 1k+ posts?
btw how to get more points?
We don't care about points etc, we care about what we do to help the community. kapich noob?
Reply to Conumdrum
Yep, its almost entertaining to me...
I logg into the computer in the morning grab a bowl of popcorn and start lmao at peoples stupid questions
and i like answering them (it gives you that warm fuzy feeling inside that says
"i just contributed to the community, because of me THF isnt going to die" )
LOL
What are these 'points' to which you refer? Are they cash redeemable?
------------------------------ The thought occurs that if I lived in a universe where merely knowing something will get me sucked into an alternate dimension and munched, I won't even live long enough to be cloned.
Reply to Mugz
No, they are not cash redeamable but you can go to the "toms store" and spend your points on a plethora of EXTREME prizes! [:jaydeejohn:4]
Oh. Damn.
Reply to Mugz
Do they have those plastic-hinged snakes, paddle balls and cheak Jax sets?
Reply to rubix_1011
Quote :
+1 on the heater core. HOWEVER, unless you buy a brand new oil cooler most(if not all) of the oil coolers in the yard are used meaning they have oil. Oil can easily damage the pump/block,etc.
------------------------------ http://farm5.static.flickr.com/4113/5052517574_1d0ebc741b.jpg
Reply to Shadow703793
I don't care much about the points too, but I DO CARE about when people like you,me,zorg,et al are given crappy titles. ie. wtf is up with "wannabe"?)
I want my old title back. 'resident a$$hole"
Reply to Conumdrum
You, sir, have been Knighted...Sir Conumdrum, Tom's Resident A$$hole.
Reply to rubix_1011
^^ HAHA
ANd i hate how all the people who just joined get so much more points than us
like i saw this one guy who had 13 posts and like 260 points and i was like WTF?!?!
Makes no sense...kind of a stupid concept to me.
Reply to rubix_1011
yeah, i liked the old way much better.
Yeah, maybe they would get response from users if they gave them gold stars or stamps on their hands after recess.
Reply to rubix_1011
^LOL
Why did they need to change a system that was put in effect like 10 years ago and it worked fine?
Seams odd to me.
To make what you once knew completely irrelevant. That's all I can think of.
Reply to rubix_1011
Sir Conumdrum, Tom's Resident Watercooled A$$hole. I am chilled where it counts..........
I like that better, I'm not on the other subforums.
I never payed too much attention to the names they give us anyway.
Reply to Conumdrum
I remember the old format. Fondly. I remember the old people too. Very fondly.
Oh, well... every time a working system gets taken over it gets replaced by the shiny new crap that doesn't work but makes the people in charge feel all important and stuff.
Discuss.
Reply to Mugz
LOL...your choice...works for me. I'll admit, you do come off rather rough around the edges, but seriously, I have seen myself getting that way with people that refuse to do even a little homework first.
"Hey guys, I was thinking about putting a computer in a mini-fridge, I am positive it will work. Here is why I am right regardless all of you have seen/heard/experienced otherwise...and how I will be a complete jerk about it..."
Reply to rubix_1011
You would think they would credit the users with the most postings here with a better title and a spike in points since they have obviously earned them.
I agree the points dont mean anything but it is a slap in the face to have noobs floating around here with more points than the regulars.
Anyone out there with their hands in the website reading this?...
Reply to englandr753
There are 1607 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Will this be a good build to overclock 2500k to 5.0GHz?
By DJDeCiBeL, 15 hours ago:
I'm the one that told him that a Silver Arrow will get to 5Ghz, so I'll take the blame...
Best offers
Top experts
