Tom's Hardware > Forum > Overclocking > CPUs > Pc doesn't boot after overclock try NEEEED HELP
Forum Overclocking : CPUs - Pc doesn't boot after overclock try NEEEED HELP
Hellow together I've tried to activate the 4th core of my Phenom II x3 720. (Motherboard gigabyte 790fxt-ud5p)
I've fist just set Acc to auto but it didn't help at all.
Then I've put the other setting (Ec something I dont remember the exact name) to Hybrid.
From that moment on the Pc didn't boot anymore...
I think that the 4th core was activated but didn't work so the Pc can't boot anymore.
Still I somehow panic a litle bit and thought of asking you before doing anything stupid.
I thought I have to reset the Cmos, my motherboard has a button for that but when I read about that in the Motherboard manual there's something written about replacing the battery and other complicated stuff(No electricyti..... ).
My question Is can't I just push the Cmos button to reset the bios? Do I have to connect turn on the Power supply before pushing the button?
Please explain me how to creal the Cmos. I thought it's just pushing a button but that manual really iritated me.
Thank you
Erdinger
Sponsored Links
Once you clear the CMOS you should be good, if you press the button and It still wont boot then you need a new battery..... 5 dollars should fix the issue.
------------------------------ 550 @ 4.0 Ghz 1.425v
BFG GTX 260 (216)
4GB G.Skill @ 940MHz
Thermaltake TP 850w
Reply to OvrClkr
------------------------------ http://img191.imageshack.us/img191/885/14y1fuqvybiiwayab.gif
Reply to overshocked
- -1 +
SUP SUP!! I want some of that ReD Kool-aid!!!!!
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
I know i really want some to but all i have is this shitty hawian punch and dr.p
Yes but my Problem is I don't know how to clear the Cmos.
Do I just have to push the button while the elecricity is flowing through the system?
Reply to erdinger
Turn off the computer then press the red button
I assume that with red button you mean the button on which its written: clear cmos... should i turn on the power supply before doing that?
Reply to erdinger
K I've found it on another page and they said that I had to turn off the power supply first.... and then push the Clear cmos button.
I did so and the system boots again.
WoW Turn off the pc an press the red button.... wouldn't that have destroyed something because of the electricity still flowing?
Reply to erdinger
LOL... sorry, i was going to elaborate but then i accedntally hit submit and i just thought
"what the hell, he will understand"
But i used to reset my mobo with the power still on...
But yeah, i would do it with the power supply unplugged
I always reset mine with the pc on. Is that bad?
Reply to nonxcarbonx
- 0 +
Usually turn my PC off and leave the PSU plugged in. I don't think you should do it while its on
Reply to AKM880
it could damage it but most mobo's have stuff in them that can cope with idiots.
LOL!
:) It really sucks when something goes wrong and you have to write the text again, happens much to often.
On my old Pc I had a Asus motherboard and after a overclock failure I just had to turn of the elecricity for 30 secs and it automatically reset the bios to default.
Now I'm asking myself if I set a to high fsb on the Gigabyte 790 fxt would it also somehow reckognize the problem and boot with normal fsb?
I think a cmos clear wouldn't help there because it doesn't change things like fsb. (right?)
Reply to erdinger
Wrong, the cmos clear will clear everything and reset them to defaults....alot of people use it to clear there fsb when they get in trouble with overclocks
- 0 +
When I buy a motherboard and cpu that i have never worked with before I make sure I write everything down to avoid having to play with the Bios for hours....Another thing you can do is use your Windows "notepad" and save it to your documents.
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
^+1
There is a reason that mobo manuals have 3-4 pages blank...its for note taking
- 0 +
It's depressing how few people realise that.
------------------------------ http://www.catb.org/~esr/faqs/smart-questions.html - I WISH PEOPLE WOULD APPLY THIS!
Reply to mugz
I've got a new very serious problem.
I have just installed the Xigmatec Hdt-s 1283 and the Fan of the cooler is not turning when I start the Pc.
I have cleaned the old thermal away (with alcohol) cleaned the surface of the Xigmatec applied new thermal paste (http://benchmarkreviews.com/index.php?option=com_content&task=view&id=170&Itemid=1&limit=1&limitstart=5)
and then mounted the fan on the cooler and connected it to the 4 pin from my motherboard (cpu_fan)
I started the Pc and (like always) all fans started to turn on 100% but the xigmatec fan was not turning. I imediately shut down the Pc (before even coming to bios).
What should I do now? Can the cooler cool the Pc well enough that I can let it come to the Bios? I'm scared that I broke the 4 pin of the Cpu when taking away the old fan (had tu pull pretty hard).
The only think I can think of is try the fan out in another pc but now my question is if I can just plug the 4 pin fan into a 3 pin connector of another pc and look if it works?
Please tell me what to do next
Erdinger
Reply to erdinger
- 0 +
Try, connecting the CPU fan (4pin) on another pc... If it still wont spin then you have a dead fan, if it does spin then you either connected it wrong (backwards) on your current mobo or broke a pin (fan header).
Btw : dont worry about the fan not spining (heatsink) if you just want to get to the bios, but if it does not spin when you boot you will achieve nothing in the bios. Just try the heatsink fan on another motherboard and make sure you connect it to the 4 pin motherboard header like I stated above.
Message edited by OvrClkr on 07-22-2009 at 04:24:43 PM
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
Make sure Smart Fan is off in the BIOS.
Reply to mugz
THANK YOU! I was to afraid even to let the system come to the bios :)
Ovrclkr said there's no danger so I went into the bios and disabled smart fan and now the fan is turning at 100%!
As I've seen in the Bios the cooler wthout the fan was already cooling the Processor to 30C (only Bios reading) so the Mobo turned out the fan because it wasn't needed!
Never underestimate a xigmatec hdt-s 1283 :)
One more question. Last time I tried to activate the 4th core the system wouldn't even boot anymore (that's why I originally opened the thread) do you think I should later on try activating the 4th core again, just with a higher Vcore and the better cooling I have now?
Reply to erdinger
- 0 +
20% of the credit goes to me and the ther 80% goes to mugs since he solved your issue....
Im glad it worked....... ;)
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
We aim to please. Accuracy costs extra.
I don't know too much about the Phenoms, but you can try activating the fourth core using a higher Vcore. The fourth core on the Phenom X3s are disabled mostly because they need a higher voltage to run at the same spec as the other three cores, or because there's an actual fault that got picked up in manufacturing. Yours could be either, so give it a try.
Reply to mugz
overshocked wrote :
^+1
:lol: :lol: :lol: :lol:
Just a fun fact here, not trying to be an ass, but the note or blank pages are added to a document by the printer, so the pages work correctly for printing. Most presses print like 16 pages up, so if the book does not work out mathematically on exactly 16 page spreads, they add blank, or note pages to the back of the book so that it does. It is neccesary for the folding and binding of the signature sets all work out to exactly 16 pages each. If the book was formated correctly during publishing, or just happened to work out with the correct number of pages exactly before it was sent to the printer, it would have no blank or note pages.
Reply to jitpublisher
- 0 +
That may be true but it works fine for note-taking so I guess that post was useless......I understand, when boredom comes around you just have to type something......
Do you work for a PRINTER company?
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Hmmm, lets see what does my handle suggest??
To the OP, sorry about hijacking your thread.
whatever, works great for note-taking though
- 0 +
bahaha +1 "overshocked"
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
- 0 +
Having worked with publishers before...
...I am now going to quietly back away slowly, get through the door, and run like hell.
The deadlines with those guys are just plain sadistic.
Reply to mugz
I've found out that I have Bios version F5 and there's another version (released 1 day later) that I would like to upgrade to (often read that unlocking cores works great with that bios).
I loaded system defaults in the Bios and enabeled legacy usb (it actually was already)
I loaded the newer bios version on a Usb stick which I plugged into the motherboard usb connectors and entered qflash after a reboot.
I disabled Keep Dmi Data and searched for the flash drive in Q-flash
It only showed me 2 flopys (I have non) and when I browsed them non of them contained the bios.
I've tried the same thing with another Usb, and I also formated the Usb for fat 32 or fat (16bit) nothing helped.
I do not have a floppy and do not want one. how should I upgrade my Bios? please help me once more
Kind regards Erdinger
Reply to erdinger
- 0 +
I'm just busting your chops, I respect your post.....We know you were not trying to be an ass, maybe a semi-ass but not a whole one...... [:waffle911]
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Could you please divert the discuscion from asses to Bios flashing?
Or best would be to combine the two topics... tell someone that hes an ass AAAND help me in the same post :)
The file(bios) I download is an Exe I don't have to run in in windows just copy onto the usb stick right?
Reply to erdinger
- 0 +
I just use Q-Flash, and flash it from Windows.... no need for thumb drives, floppy's or none of that nonsense....
Sorry for the semi-hijack, just some morning humor.....
Message edited by OvrClkr on 07-24-2009 at 04:40:10 PM
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
OK now I feel like a moron.
I just opened the exe and put the containing files to the usb stick....
Now I was able to update the bios...
I was reading more then 45 minutes about flashing the bios..
I read several step by step instructions but there was never written to try and start the file I've downloaded ^^ it must be to clear..
I suck
Erdinger
Ps: how can u flash from windows with Q-flash?
Message edited by erdinger on 07-24-2009 at 04:43:16 PM
Reply to erdinger
- 0 +
Do you have the exe file on the hard drive? desktop?
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Yes the Exe file is the file I've downloaded from the Gygabite page.
Then after some hours I've seen that it is an exe launched it (from within a usb stick I had transfered it to) and put the data it contained onto the Usb stick from which I was then able to update the Bios via Q-flash (when booting)
I tried again to unlock the 4th core with increased Vcore (0.5 Volt) and increased Nb Vdd but it just wouldn't help so I gave up on the 4th core.
Reply to erdinger
- 0 +
I will show you an example of how I flash my boards :
http://www.asrock.com/mb/download. [...] i&s=AM2%2b
just click on the exe and the rest is history....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
There are 1145 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
