Tom's Hardware Forums » Homebuilt Systems » General Homebuilt » Do these system temps look fine to you??
Add a reply
Overall, do these system temps look fine to you??
This poll will be closed on 07-09-2009 at 06:00 PM
Warning, if you click on "see results", you won't be able to vote
 Word :   Username :
Bottom
Author
 Thread : Do these system temps look fine to you??
Profile: journeyman
More Information
Do these system temps look fine to you?? I took screen shots idle & under load. This is a air cooled, mATX case & there is a link below to the specific case.
I am using Sensor View program to take readings -
IDLE
http://www.ctrlaltdelpc.com/images/temps.jpg
UNDER LOAD
http://www.ctrlaltdelpc.com/images/temps2.jpg
I am currently running this config:
Manufacturer: built by: |Landis| - Me
Chassis: Thermaltake LanBox MicroATX Case
http://www.newegg.com/Product/Prod [...] 6811133035
Motherboard: ASUS P5E-VM HDMI LGA 775
Intel G35 HDMI Micro ATX Intel Motherboard
Processor: Intel Core 2 Duo E8400 @ 3.00GHz (2 CPUs)
Memory: 4096MB Crucial Tracer DDR2 800 [4-4-4-12]
Hard Drive(s): 300GB VelociRaptor [10k RPM, SATA 3.0Gb/s] & 2- 320 GB [e.sata]
Optical Drive(s): 2- SAMSUNG 20X DVD Burner w/LightScribe SATA
Video Card: nVidia GeForce 8800 GTS v.ACS [320mb]
Power Supply: PC Power & Cooling 750W PSU
Monitor: Acer 19" Widescreen Flat Panel
Sound Card: SB X-Fi Titanium Fatal1ty Professional
Speakers/Headphones: Alienware® Ozma 7™ Headphones with S-Logic™ Technology
Keyboard: Wolf King Timber Wolf Gaming Keyboard
Mouse: Razer Lachesis Gaming Mouse [Banshee Blue 9 Buttons 1 x Wheel USB Laser 4000 dpi]
Operating System: Windows XP Professional - SP3
Message edited by mychael616 on 07-10-2008 at 09:38:19 AM
Related Pr oduct
Profile: addict
More Information
omg very good
Profile: nimble knuckle
More Information
Yes, your temps are fine.
Sorry, did you want a cookie or something?
http://twiggs.org/images/5203-bakery-crisp-chocolate-chip-cookie.jpg
:kaola:
If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Profile: journeyman
More Information
Sure...
Thermaltake Lanbox | The only Sli 939 mATX board by eVGA | AMD 2.4ghz X2 | OCZ DDR 400 RAM [2-3-2-5] | 2- 150gb RaptorX & 2- 320 GB [e.sata] | nVidia GeForce 8800 GTS v.ACS [320mb] | SB Audigy 2 ZS Audio
Tenacity & Attention to Detail
Profile: Faithful Poster
More Information
mychael616,
Sensor View is a non-standard monitoring utility, which like the utilities packaged with motherboards, shows CPU temperature only, but not Core temperatures. Since it's best to monitor both sets of temperatures, as well as all the other system parameters shown in Sensor View, download SpeedFan 4.34. SpeedFan can be accurately calibrated by using my Core 2 Quad and Duo Temperature Guide, which explains the differences between CPU temperature and Core temperatures.
If you're interested in monitoring Core temperatures only, then the most accurate utility available is Real Temp 2.6. The link shown below in my signature contains a link to Real Temp in the Introduction Section, as well as a link to SpeedFan in the Tools Section. I highly recommend that you go to Real Temp's download page, click on the link to the documentation, and read it thouroghly. The documentation explains the DTS sensor problems that exist with 45 nanometer processors, and how to test your E8400.
Hope this helps,
Comp :sol:
Message edited by CompuTroni x on 07-12-2008 at 11:36:33 PM
Q6600 G0 @ 3.6 | Xigmatek HDT-SD964
Ambient 22c | CPU 60c | Core 67c
Vcore Load 1.440 | VID 1.3000
Core 2 Quad and Duo Temperature Guide --> http://www.tomshardware.com/forum/ [...] ture-guide
Profile: journeyman
More Information
Thanks!! That did help. I checked out that program(s) and took a screenshot of the results.
http://www.ctrlaltdelpc.com/images/temps3.jpg
<--click to view large size-->
Message edited by mychael616 on 07-15-2008 at 10:43:25 AM
Add a reply
Google Ads
